Hello Hermann,
I don't know your specific instrument.
>From other instruments I know there are two different binblocks;
an indefinit binblocks, which reads like '#0', and a definit length
binblocks, which reads like '#9000000005'.
This means: #9 --> length field is 9 characters
000000005 --> length in decimal, i.e. 5 Bytes.
2nd example:
#234 --> length field is 2 characters, length is 34 bytes.
After this length spec the data bytes follow.
Hope this helps.
Werner.
> -----Original Message-----
> From: hermann.ruckerbauer@infineon.com
> [mailto:hermann.ruckerbauer@infineon.com]
> Sent: Tuesday, January 14, 2003 10:02
> To: VEE vrf
> Subject: [vrf] AW: Re: File transfer over GPIB ==> * as READ BINARY
> until EOF not possible ????
> Hello,
> after getting this response (thanks to Bruno) I read the
> manual again, and
> here it is mentioned as you described
> (* is only working for some special read (e. g. read from
> file), but not for
> Read from GPIB).
> So the only solution I found so far is to read byte by byte
> until an error
> occurs. This works fine,
> but it takes a long time until the sequence is finished.
> Any better idea how to utilze the binblock read ?
> thanks
> Hermann
> Infineon Technologies
> Hermann Ruckerbauer
> MP TI PD DES 5 / MchB / Room 3448
> Balanstrasse 73
> D-81541 Munich
> Germany
> Phone: +49 (89) 234 25041
> Fax.: +49 (89) 234 715757
> e-mail:Hermann.Ruckerbauer@infineon.com
> -----Ursprngliche Nachricht-----
> Von: Beliveau, Bruno [mailto:BrunoBeliveau@solectron.com]
> Gesendet am: Montag, 13. Januar 2003 22:49
> An: VEE vrf
> Cc: VEE vrf
> Betreff: [vrf] Re: File transfer over GPIB ==> * as READ
> BINARY until EOF
> not possible ????
> With a file I/O transaction, you click on the "Size:" button
> and it changes
> to "To End" (and the quantity to "*"). With a GPIB I/O
> transaction, the EOF
> is not defined (not to my knowledge), so the same trick does not work.
> -----Message d'origine-----
> De: hermann.ruckerbauer@infineon.com [
> <mailto:hermann.ruckerbauer@infineon.com> ]
> Date: 13 janvier 2003 08:19
> I have tried the program send by Phil (thanks a lot, see his
> mail below),
> but my VEE (v6) is reporting an error, when it detects a # sign in the
> binary
> data flow. So I tried the pure binary transfer.
> This works fine, if I do know, how much data is transfered,
> as I can give
> the size of the 1dim array I'm going to transfer.
> unfortinally I do not know how big the file is I would like
> to transfer.
> Therefore I took a look to the advanced programming guide
> which says on page
> 526 that a * will do a read binary until EOF. But when trying
> to write a
> star
> into the corresponding "NumElements" field of the direct IO
> object VEE is
> reporting a syntax error, when pressing OK to accept the command!
> Is this a bug OR something wrong in the handbook OR am I just
> to stupid do
> use it correct ????
> Von: Phil McRevis [ mailto:philmcrevis@hotmail.com
> <mailto:philmcrevis@hotmail.com> ]
> Gesendet am: Dienstag, 10. Dezember 2002 15:48
> Perhaps this will help, but PLEASE excuse me if this
> attachment is not
> appropriate. Even though my days of code development are
> largely over, I
> can't break away from looking at this group every now and
> then. Is this
> group similar to crack? Maybe. Gotta get a fix!
> Anyway, I used to use this program to transfer scope images
> via gpib. While
> I don't have a licensed copy of VEE at my disposal right now
> to verify this
> attachment (I suppose I could look at it in notepad), I
> recall using a
> binblock transfer to accomplish this task.
> Obviously, some customization will be necessary based on the
> potential
> unique commands of your individual scope(s), but that should
> be a simple
> investigation. First issue the command in an I/O transaction
> object to send
> the scope image, then perform a binblock read of byte array format.
> I also recall preferring this simple little program because I
> didn't like
> the dependence of IntuiLink. Hey, if I can get the job done
> with one or two
> simple VEE objects, why bog myself down with IntuiLink?
> >From: "Jay Nemeth-Johannes" <jayj@ventureconsult.com>
> >Reply-To: "Jay Nemeth-Johannes" <jayj@ventureconsult.com>
> >I think you will need to be more specific in order to get an answer.
> >IntuiLink for the scope uses a set of documented scope commands for
> >transferring a bitmap screen image. The spectrum analyzers
> use a similar
> >capability for a printer dump and then interpret the pcl
> codes to recreate
> >the image. In both cases, the commands to get the screen
> image exist in
> >the instrument.
> >If you want the same thing for a non-Agilent instrument, you
> are going to
> >have to read the programming manual and see if the
> capability exists. If
> >it doesn't, which is often the case, your only option is to
> pull the trace
> >data and manually create the rest of the screen with an
> external graphics
> >pack and then re-import.
> >From: Dale Hauck [ mailto:dhauck@Anadigics.com
> <mailto:dhauck@Anadigics.com> ]
> >Sent: Wednesday, December 04, 2002 1:32 PM
> > Specifically image files, screen capture from an instrument.
> >Agilent uses Intuilink to overcome this. What can we do for
> non- Agilent
> >instruments? I am unable to get source code for Intuilinks
> screen capture.
> >Anyone?
> > The key seems to be in editing the header information to
> reflect the
> >appropriate file format.
> You are currently subscribed to vrf as:
> To send messages to this mailing list, email
> "vrf@it.lists.it.agilent.com".
> You are currently subscribed to vrf as: Werner_Jacoby@Agilent.com
2nd example:
Hope this helps.
Werner.
> To: VEE vrf
> Hello,
> manual again, and
> file), but not for
> Read from GPIB).
> until an error
> thanks
> Hermann
> Hermann Ruckerbauer
> Balanstrasse 73
> D-81541 Munich
> Germany
> An: VEE vrf
> Cc: VEE vrf
> BINARY until EOF
> not possible ????
> and it changes
> mail below),
> binary
> as I can give
> to transfer.
> which says on page
> to write a
> star
> object VEE is
> to stupid do
> use it correct ????
> attachment is not
> largely over, I
> then. Is this
> via gpib. While
> to verify this
> recall using a
> potential
> be a simple
> object to send
> didn't like
> with one or two
> use a similar
> codes to recreate
> image exist in
> >the instrument.
> are going to
> pull the trace
> external graphics
> non- Agilent
> screen capture.
> >Anyone?
> reflect the
