Never mind, I think I found what's happening. A test case worked fine.
The cells I was coloring already had a shading or background color
assigned, so somehow those effects overlapped. I simply need to modify the
template document and change the backgorund of the cells in question to
transparent then it should be fine
Rich
Richard Kleinhenz
mailto:scubaman@us.ibm.com
845-892-2617
Richard
Kleinhenz/Fishkil To: "VEE vrf" <vrf@it.lists.it.agilent.com>
l/IBM@IBMUS cc: "VEE vrf" <vrf@it.lists.it.agilent.com>
Subject: [vrf] Re: activeX: setting colors in Word table - HELP!
10/31/2002 08:53
AM
Please respond to
Richard Kleinhenz
Still can't figure out why I don't ge the colors I expect - what am I
missing?
Rich
Richard Kleinhenz
845-892-2617
Richard
l/IBM@IBMUS cc:
Subject: [vrf] activeX:
10/30/2002 11:08
AM
Please respond to
Richard Kleinhenz
I'm trying to format some field colors in a table in a word document.
wdColorRed comes up as 255 and displays bright red. wdColorGreen,
wdColorLightGreen and wdColorBrightGreen all come up with huge numbers and
are not a green tone. What am I missing? The actual activeX call I use is
wordapp.ActiveDocument.tables(table).Range.Cells(cell).Range.Shading.BackgroundPatternColor=bgcolor,
I'm feeding in table, cell and bgcolor. Maybe it would help if I knew how
the colors are coded, but I thought the built-in values at least would
work.
Rich
Richard Kleinhenz
845-892-2617
You are currently subscribed to vrf as: scubaman@us.ibm.com
To send messages to this mailing list, email
"vrf@it.lists.it.agilent.com".
missing?
Rich
Richard Kleinhenz
845-892-2617
Richard
l/IBM@IBMUS cc:
Subject: [vrf] activeX: setting colors in Word table
10/30/2002 11:08
AM
Please respond to
Richard Kleinhenz
work.
Rich
Richard Kleinhenz
845-892-2617
