Justin and all
We used the Demo Version of the J.S.Payne OCX and we had all functionality
we required. Only difference is that a message pops up on OCX
initialisation in demo version.
We then bought the registered version and no functional difference, just the
message does not pop up.
Regards
Andrew F
Genesys IBS
----- Original Message -----
To: VEE vrf <vrf@it.lists.it.agilent.com>
Cc: VEE vrf <vrf@it.lists.it.agilent.com>; Steve Payne <jspayneco@yahoo.com>
Sent: Thursday, November 07, 2002 8:57 PM
Subject: [vrf] Re: VEE - Parallel Port
> Justin,
> I routinely use the JSPayne IO ActiveX objects for serial IO with Vee
> 6.01 & Win2000. They work well. I have not tried the parallel port
> objects however. One thing concerns me - normally demo software of this
> type works correctly for some time period or simply puts an annoying
> message on the screen each time your code runs. I believe you should be
> able to make the JSPayne demo work correctly and since you can't,
> perhaps there is something substantially wrong. It might be your use of
> Win98. I suggest an Email to JSPayne asking what you should be able to
> do with the demo and also some experimentation with the serial objects
> since I know these can work with Vee.
> Barrie
> Justin Abbott wrote:
> > Good Day All
> > Trying to access the parallel port to send a control word (1011 ...) to
a
> > test chip. I understand VEE does not allow access to the parallel port
but
> > 3rd party software (JS Payne) I/O Active X will allow access.
> > Has anyone successfully used this? The downloadable demo version gave
me
> > access to the Active X components with in my VEE programming window, but
> > would not run. I am assuming if I buy the package this problem will be
> > solved. Anyone have experience with this or other recommendations??
> > System: VEE 6.1, Win 98
> > Thanks
> > Justin
> You are currently subscribed to vrf as: AndrewF@genesysibs.com
> To send messages to this mailing list, email
"vrf@it.lists.it.agilent.com".
"mailto:owner-vrf@it.lists.it.agilent.com.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.408 / Virus Database: 230 - Release Date: 24/10/02
Regards
Andrew F
Genesys IBS
> Justin,
> Barrie
> > Good Day All
a
but
me
> > Thanks
> > Justin
Trying to access the parallel port to send a control word (1011 ...) to a
test chip. I understand VEE does not allow access to the parallel port but
Has anyone successfully used this? The downloadable demo version gave me
Thanks
Justin
