"Blalock, William T." <WILLIAM.T.BLALOCK@saic.com> wrote:
> Thanks Stan.
> Your method is definitely easier to implement. I just put in a loop with a
> couple of variables for number of reads and array size. I'm curious though,
> is there a way to add or delete actual I/O transactions programmatically?
> Thanks again, Todd.
No simple way.
Stan
> Thanks Stan.
> Thanks again, Todd.
No simple way.
Stan
I need to make multiple reads of data arrays coming from an instrument. The
problem is the number of reads
and arrays can change from test to test. I want to make this transparent.
Is there any way to set up I/O transactions on the fly? Maybe using
records? Any help appreciated. Using VEE 6.03, Win2k.
William T. Blalock
Science Applications International Corporation
Engineering Technician/Technical Analyst
E-Mail: blalockw@saic.com
RF Lab (Comm / DSN):(256) 313-7869 / 897-7869
RF Lab Fax (Comm / DSN):(256) 313-7861 / 897-7861
