Hi Jeff,
This is only a problem if the function/program doesn't quit before you try
do do something like move or delete the files.
I used to have this problem when files would be left open by my functions,
and then the housekeeping functions I had written came along and tried to
archive the files. Then my C-Script functions (called from Vee) would quit
with an error causing Vee to handle the error.
In general, close the files when there is a high probability that you will
not need to use them again. If you do need to append data to the file, then
make sure that the Clear File tick box is NOT ticked.
Cheers,
Graeme
(Still between jobs!)
> -----Original Message-----
> From: Tostenrude, Jeff [mailto:Jeff.Tostenrude@Nextel.com]
> Sent: 20 October 2003 22:13
> To: VEE vrf
> Subject: [vrf] RE: FW: writing data to multiple files
> Thanks everyone for your responses. I used LabView quite a bit
> 7-8 years ago and never used VEE, so I'm still learning.
> I have not been explictly closing the files after I have finished
> writing to them and everything seems to work fine. Is there a
> problem with this?
> Thanks,
> Jeff
> From: Goldberg, Mark [mailto:Mark.Goldberg@ATK.COM]
> Sent: Monday, October 20, 2003 1:46 PM
> To: VEE vrf
> Subject: [vrf] FW: writing data to multiple files
> Original message did not see to get through??
> Sent: Monday, October 20, 2003 11:52 AM
> To: 'Tostenrude, Jeff'; VEE vrf
> Subject: RE: [vrf] writing data to multiple files
> Jeff,
> Here is one way I use. When your program completes a test call the example
> as a user function and it will generate a time and date file name. Or you
> can customize it with a test type added to the name or different combos.
> Hope this helps.
> Mark
> Sent: Monday, October 20, 2003 11:26 AM
> To: VEE vrf
> Subject: [vrf] writing data to multiple files
> I have a test loop which outputs spectrum analyzer data to a
> file. How do I
> tell VEE to output the data to a new file each time, instead of using the
> same file?
> TIA,
> Jeff
Cheers,
Graeme
> To: VEE vrf
> problem with this?
> Thanks,
> Jeff
> To: VEE vrf
> Jeff,
> Hope this helps.
> Mark
> To: VEE vrf
> file. How do I
> same file?
> TIA,
> Jeff
Jeff,
Hope this helps.
Mark
To: VEE vrf
I have a test loop which outputs spectrum analyzer data to a file. How do I
same file?
TIA,
Jeff
You are currently subscribed to vrf as: Mark.Goldberg@ATK.COM
begin 600 uniquefilename.vee
M*'-A=F5&;W)M870@(C(N,R(I#0HH9&%T92`B36]N(#(P+T]C="R,#`S(#$Q
M.C0Y.C4P("(I#0HH=F5E<F5V("(V+C(B*0T**'!L871F;W)M(")00R(I#0HH
M97AE8TUO9&4@=C8I#0HH9FEL=&5R3D%.(#`I#0HH=V]R:W-P86-E4W1A8VMI
M;F=/<F1E<B!-*0T**'-Y<V-O;F9I9PT**&EO9&5V:6-E(")#;VTQ(@T**'1Y
M<&4@4V5R:6%L*0T**&=A=&5W87D@(E1H:7,@:&]S="(I#0HH8VAA;FYE;"`P
M*0T**')E861497)M(")<;B(I#0HH9G,@(BPB*0T**&5O;"`B7&XB*0T**&UU
M;'1I1FEE;&0@9&%T84]N;'DI#0HH87)R87E&;W)M870@;&EN96%R*0T**'1I
M;65O=70@-2D-"BAB>71E3W)D97(@,"D-"BAI<TQI=F4@,"D-"BAM;V1E;"`B
M(BD-"BAB875D4F%T92`Y-C`P*0T**&-H87)3:7IE(#@I#0HH<W1O<$)I=',@
M,2D-"BAP87)I='D@;V9F*0T**&AA;F1S:&%K92!O9F8I#0HH<F5C=D)U9F9E
M<E-I>F4@-#`Y-BDI*0T**%-A=F5#1B!N;RD-"BAD979I8V4@,"!23T]40T].
M5$585`T**'!R;W!E<G1I97,-"BAT<FEG36]D92!D96<I#0HH;F5X=$E$(#DI
M#0HH<&]P=7!4:71L951E>'0@(E5N=&ET;&5D(BD-"BAP;W!U<$UO=F5A8FQE
M(#$I*0T**&1E=FEC94QI<W0-"BAD979I8V4@,"!&3U)-54Q!#0HH<')O<&5R
M=&EE<PT**&5X<'(@,2`B;F]W*"D[(BDI#0HH:6YT97)F86-E#0HH;W5T<'5T
M(#$-"BAN86UE(")297-U;'0B*0T**'1A9R`B4F5S=6QT(BD-"BAL;V-K(&YA
M;64@8V]N<W1R86EN=',I#0HH;W!T:6]N86P@>65S*2DI*0T**&1E=FEC92`R
M(%1%6%1$25-03$%9#0HH:6YT97)F86-E#0HH:6YP=70@,0T**&YA;64@(D1A
M=&$B*2DI*0T**&1E=FEC92`S(%1/4U1224Y'#0HH<')O<&5R=&EE<PT**'1R
M86YS86-T:6]N<R`Q(")74DE412!415A4(&$@1$%413I$35D@5$E-13I(35,Z
M2#(T($5/3"(I*0T**&EN=&5R9F%C90T**&EN<'5T(#$-"BAN86UE(")A(BD-
M"BAO<'1I;VYA;"!Y97,I*0T**&]U='!U="`Q#0HH;F%M92`B<F5S=6QT(BD-
M"BAL;V-K(&YA;64@8V]N<W1R86EN=',I*2D-"BAI;7!L96UE;G1A=&EO;@T*
M*&%T='(@:6]P871H('-T<FEN9R!W<FET92`B<W1R:6YG(@T**')E861497)M
M(")<;B(I#0HH9G,@(B`B*0T**&5O;"`B7&XB*0T**&UU;'1I1FEE;&0@9G5L
M;%-Y;G1A>"D-"BAA<G)A>49O<FUA="!B;&]C:RDI*2D-"BAD979I8V4@-B!4
M15A41$E34$Q!60T**'!R;W!E<G1I97,-"BAN86UE(")&:6QE($YA;64B*2D-
M"BAI;G1E<F9A8V4-"BAI;G!U="`Q#0HH;F%M92`B1&%T82(I*2DI#0HH9&5V
M:6-E(#@@1D]2355,00T**'!R;W!E<G1I97,-"BAN86UE(")&;W)M870@;F%M
M92(I#0HH97AP<B`S#0HB<W1R9G)O;6QE;BAA+#`L,BDK<W1R9G)O;6QE;BAA
M+#,L,RDK<W1R9G)O;6QE;BAA+#<L-"DK7")?7"(K<W1R9G)O;6QE;BAA+#$R
M+#(I(@T*(BMS=')F<F]M;&5N*&$L,34L,BDK<W1R9G)O;6QE;BAA+#$X+#(I
M*UPB+F1A=%PB(B`B(BDI#0HH:6YT97)F86-E#0HH:6YP=70@,0T**&YA;64@
M(D$B*0T**&]P=&EO;F%L('EE<RDI#0HH;W5T<'5T(#$-"BAN86UE(")297-U
M;'0B*0T**'1A9R`B4F5S=6QT(BD-"BAL;V-K(&YA;64@8V]N<W1R86EN=',I
M#0HH;W!T:6]N86P@>65S*2DI*0T**&-O;F9I9W5R871I;VX-"BAC;VYN96-T
M($0R.C$@1#$Z,2D-"BAC;VYN96-T($0P.C$@1#(Z,2D-"BAC;VYN96-T($0T
M.C$@1#,Z,2D-"BAC;VYN96-T($0R.C$@1#0Z,2DI*0T**&-O;G1E>'1#87)R
M:65R#0HH=VYD4F5S=&]R961/<FEG:6X@,B`R*0T**'=N9%)E<W1O<F5D17AT
M96YT(#@Q-"`V.#DI#0HH=VYD4W1A=&4@;6%X*0T**&%C=&EV92!D971A:6PI
M#0HH9&5T86EL#0HH97AT96YT(#$P-#(@.3$W*0T**&%N8VAO<E!T("TT(#@I
M#0HH8V]N9FEG=7)A=&EO;@T**&1E=D-A<G)I97)&;W(@,`T**&%C=&EV92!O
M<&5N*0T**&EC;VXI#0HH;W!E;@T**&5X=&5N="`W,2`S,2DI#0HH=&5R;6EN
M86QS(&]N*0T**'!I;D-E;G1E<B`Q-3`@,C<P*2D-"BAD979#87)R:65R1F]R
M(#(-"BAA8W1I=F4@;W!E;BD-"BAI8V]N*0T**&]P96X-"BAE>'1E;G0@,C`U
M(#(W*2D-"BAP:6Y#96YT97(@.#(P(#(W,"DI#0HH9&5V0V%R<FEE<D9O<B`S
M#0HH86-T:79E(&]P96XI#0HH:6-O;@T**&5X=&5N="`U,R`Q-2DI#0HH;W!E
M;@T**&5X=&5N="`R-S4@-S<I*0T**'1E<FUI;F%L<R!O;BD-"BAP:6Y#96YT
M97(@-#8P(#(W,"DI#0HH9&5V0V%R<FEE<D9O<B`V#0HH86-T:79E(&]P96XI
M#0HH:6-O;@T**&5X=&5N="`V,B`P*2D-"BAO<&5N#0HH97AT96YT(#(P-2`R
M-RDI#0HH<&EN0V5N=&5R(#@U,"`U,3`I*0T**&1E=D-A<G)I97)&;W(@.`T*
M*&%C=&EV92!O<&5N*0T**&EC;VX-"BAE>'1E;G0@.#$@,"DI#0HH;W!E;@T*
M*&5X=&5N="`U,34@-C$I*0T**'1E<FUI;F%L<R!O;BD-"BAP:6Y#96YT97(@
M,S<P(#4Q,"DI#0HH8V]N;F5C="!$,CHQ($0Q.C$-"BAP;VEN=',@,B`V-3`@
M,C<P(#<Q-2`R-S`I*0T**&-O;FYE8W0@1#`Z,2!$,CHQ#0HH<&]I;G1S(#(@
M,C,X(#(W,"`R.3`@,C<P*2D-"BAC;VYN96-T($0T.C$@1#,Z,0T**'!O:6YT
M<R`R(#8X,"`U,3`@-S0U(#4Q,"DI#0HH8V]N;F5C="!$,CHQ($0T.C$-"BAP
M;VEN=',@-B`V-3`@,C<P(#8W,"`R-S`@-C<P(#,S,"`V,"`S,S`@-C`@-3$P
M(#@P(#4Q,"DI*0T**'-T86-K:6YG3W)D97(@,"`R(#$@,R`T*2D-"BAN=6UB
M97)&;W)M871S#0HH<F5A;$9O<FUA="!S=&%N9&%R9"D-"BAR96%L4VEG1&EG
M:71S(#0I#0HH<F5A;%)A9&EX4W!E8R`T*0T**&EN=&5G97)"87-E(&1E8VEM
(86PI*2DI#0H=
end
