vrf VRF - text wrap or limiter
Question asked by VRFuser on Feb 6, 2002
Hello Georg and all others,
It did work fine on mine, until I tried to find the difference between my PC and the other one.
I was trying to get it to work on another PC.  Now I get this error on my machine.
<<...OLE_Obj...>>
The file Richtx32.ocx is present on both machines.  I used regdrop.exe to make sure it was registered.
But, now it does not work on my machine.  Any ideas on what I messed up?
Where is the best place to download or update the Microsoft Rich Textbox Control 6.0 from?
<<...OLE_Obj...>>
Thanks again for the help,
Scott Anderson
Quality Analyst II
ADC Worldwide Operations
Tel : 952.403.8311
Fax : 952.403.8544
MS : 509
scott_anderson@adc.com
Learn about ADC - The Broadband Company at www.ADC.com
> Mailing Address:  P.O. Box 1101, Minneapolis, MN  55440-1101
> Office Address:  1187 Park Place, Shakopee, MN  55379
Sent: Friday, February 01, 2002 4:18 PM
To: Anderson, Scott
Subject: AW: vrf VRF - text wrap or limiter
Scott,
does your runtime app run on the same pc?
If not, check, if the activeX component is installed there.
Georg
Von: Anderson, Scott [mailto:Scott_Anderson@adc.com]
Gesendet: Freitag, 1. Februar 2002 21:15
An: Vrf (E-mail)
Cc: 'Georg Nied'
Betreff: RE: vrf VRF - text wrap or limiter
Hello all,
Thanks Georg, for the example using the Rich text box.
It works fine on my machine (95), but not when used in my runtime
application?
any ideas, attached is a screen shot of the error and the program example.
Scott Anderson
Quality Analyst II
Tel : 952.403.8311
Fax : 952.403.8544
MS : 509
Sent: Friday, February 01, 2002 3:25 AM
To: Anderson, Scott; Vrf (E-mail)
Subject: RE: vrf VRF - text wrap or limiter
Hello Scott,
the best thing you could do is to use the rich text box axctiveX control
(MS).
I appended your example with I changed to use it.
        Georg Nied
   Software-Development
Hansestr.7 - 51149 Cologne
        Germany
Mail: info@gn-software.de
> From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On
> Behalf Of Anderson, Scott
> Sent: Wednesday, January 30, 2002 3:17 PM
> To: Vrf (E-mail)
> Subject: vrf VRF - text wrap or limiter
> Hello all,
> First thanks to all that sent examples on my last question for the list
> selection, they worked good.
> Now I am trying to find a way to limit the users of a program to only be
> ably to put in 250 characters.
> Is there a way to have the text wrap around instead of typing past the end
> of the box?
> 5 Rows is easy to limit them to, but not a certain # of number of
> characters.
>  <<text wrap or limiter.vee>>
> Thanks for the help,
> Scott Anderson
> Quality Analyst II
> Tel : 952.403.8311
> Fax : 952.403.8544
> MS : 509
> Copyright 2001 ADC Telecommunications, Inc.  This communication is the
> property of ADC and may contain information that is confidential and/or
> privileged.  This communication has been transmitted for the exclusive use
> of the intended recipient.  If you are not the intended recipient, please
> send a copy of it with the title "Received in error" to email_team@adc.com
> and then delete the email and destroy any copies of it.  You may not
> otherwise distribute, copy, or use this communication or the
> information in
> it in any manner.  Please contact ADC at 952 938-8080 if you need
> assistance.  Thank you for your cooperation.
Copyright 2002 ADC Telecommunications, Inc. This communication is the property of ADC and may contain information that is confidential and/or privileged. This communication has been transmitted for the exclusive use of the intended recipient. If you are not the intended recipient, please send a copy of it with the title "Received in error" to adc_messenger@adc.com and then delete the email and destroy any copies of it. You may not otherwise distribute, copy, or use this communication or the information in it in any manner.  Please contact ADC at 952 938-8080 if you need assistance. Thank you for your cooperation.
