Hi Joe,
three years ago I wrote a programm to operate a TDS 784 on 100 kV level via
Ethernet and fibre optics. This programm is based on the instrument driver
for TDS 400, 500, 600 scopes and is used on windows and unix (no activeX).
The Ethernet connection is done via HP E2050 (LAN/HP-IB gateway). Newer TDS
scopes (3000, 5000, 7000 series) needs a totally different GPIB driver. The
old tktds4_6.id is not useable for this scopes.
If your application fits to the tktds4_6.id with HP E2050, I will send you
the whole program.
Tobias Schneegans
Berliner Elektronenspeicherring-Gesellschaft
fuer Synchrotronstrahlung mbH (BESSY) phone +49 30 6392-4637
Albert-Einstein-Str. 15 fax +49 30 6392-4859
D-12489 Berlin Tobias.Schneegans@mail.bessy.de
At 01.02.2002 19:48, you wrote:
>Greetings,
>Has anyone been successful at communicating with a Tektronix TDS oscope over
>Ethernet?
>Did you use the activeX control or another method?
>Would anyone want to share a small example?
>Best Regards,
>Joe Flynn
the whole program.
Tobias Schneegans
>Greetings,
>Ethernet?
>Best Regards,
>Joe Flynn
