Mike,
Thanks for your answer... it really what I want.
Paul
----- Original Message -----
To: Paul <paul_duran1000@hotmail.com>
Cc: VEE Reflector (E-mail) <vrf@lvld.agilent.com>
Sent: Wednesday, July 17, 2002 4:26 AM
Subject: vrf Get field from formatted file
Paul,
You just need to use the 'read token' feature - it's a very elegant
solution for this type of problem. See the attached example.
Mike Watts
_______________________________________________________________________
Michael Watts, Consultant PO Box 92
on the web: www.PreciselySo.Co.UK Exeter,Devon
e-mail: MJWC@PreciselySo.Co.UK England
tel: +44 7714 339 729 EX4 2YY
Paul
Paul,
Mike Watts
one com port box and added a device name (if memory serves correctly) input
pin and cycled through the port names using a for range box and a formula
box to drive the serial port object.
I don't think VEE has any limit on the number of ports.
Mark
Sent: Wednesday, July 17, 2002 7:05 AM
To: vrf
Subject: vrf talk to 10 serial ports
Does anyone know how to connect more than 4 serial ports in VEE. I have 10
ports (com1 to com10) but VEE only supports 4. Thank you.
Tim Xing
Dept. of Engineering
Labconco
8811 Prospect Ave.
Kansas City, MO. 64132
(816) 822-3759
