Hi Scott, I just joined the reflector and I don't know the background BUT:
I had a vee program that I wanted to have email me when something happened.
I tried the usual interfacing to outlook, outlook express didn't have the
hooks I need. Any way I was successful about 50% of the time. Outlook
sometimes didn't pass the message onto the mail server then all of a sudden
I would get a weeks worth of messages. Any way I wrote a dll in VB that I
called with vee. The VB DLL would pass the message on to the pop3 server
that you could define. If you are interested I can pass you on more details.
Scott MacEachern
_____________________________
Scott MacEachern A.Sc.T.
Product Specialist
(705) 324-2592 or
pager (888) 724-3861 ext 558-1336
scottm@hq.lindsayelec.com
----- Original Message -----
To: <SThompson@cmltduk.com>
Cc: <vrf@lvld.agilent.com>
Sent: Friday, February 08, 2002 11:51 AM
Subject: RE: vrf Reading e-mails with Vee
Hi Scott
My code was written by someone else: I don't know much about Active-x
controls. You're welcome to check this out, though.
<<EmailAlert.vee>>
K2
Kevin 2 Hasselquist
Senior RF Technician
Nokia Mobile Phones, Inc.
12278 Scripps Summit Drive San Diego, CA 92131
Phone: 858-831-4731 Fax: 858-831-6507
Mobile: 619-322-4288
E-mail: Kevin.Hasselquist@Nokia.com
From: ext Scott Thompson [mailto:SThompson@cmltduk.com]
Sent: 08 February, 2002 8:17 AM
To: Hasselquist Kevin (NMP/SanDiego)
Hi Kevin
You have recently posted an e-mail on the subject of getting your VEE code
to e-mail you when and error has occurred. I am trying to use ActiveX to
find out when new mail has arrived, and also pull the main body of the
e-mail into VEE. If you have the time I would be very interested in any
examples you have.
Best regards
Scott Thompson
Channel Master UK
Scott MacEachern
Product Specialist
(705) 324-2592 or
Hi Scott
<<EmailAlert.vee>>
K2
Kevin 2 Hasselquist
Hi Kevin
examples you have.
Best regards
Scott Thompson
Channel Master UK
three years ago I wrote a programm to operate a TDS 784 on 100 kV level via
Ethernet and fibre optics. This programm is based on the instrument driver
for TDS 400, 500, 600 scopes and is used on windows and unix (no activeX).
The Ethernet connection is done via HP E2050 (LAN/HP-IB gateway). Newer TDS
scopes (3000, 5000, 7000 series) needs a totally different GPIB driver. The
old tktds4_6.id is not useable for this scopes.
If your application fits to the tktds4_6.id with HP E2050, I will send you
the whole program.
Tobias Schneegans
Berliner Elektronenspeicherring-Gesellschaft
fuer Synchrotronstrahlung mbH (BESSY) phone +49 30 6392-4637
Albert-Einstein-Str. 15 fax +49 30 6392-4859
D-12489 Berlin Tobias.Schneegans@mail.bessy.de
At 01.02.2002 19:48, you wrote:
>Greetings,
>Has anyone been successful at communicating with a Tektronix TDS oscope over
>Ethernet?
>Did you use the activeX control or another method?
>Would anyone want to share a small example?
>Best Regards,
>Joe Flynn
