<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META content="MSHTML 5.50.4916.2300" name=GENERATOR></HEAD><BODY><DIV><FONT face=Arial color=#0000ff size=2><SPANclass=890345414-03092003>Keith,</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPANclass=890345414-03092003></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890345414-03092003>Usethe ShowPanel() and HidePanel() functions to control when a panel appears (byname), as well as the size and position of the panel.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPANclass=890345414-03092003></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890345414-03092003><P><FONT face=Arial size=2>_____________________________________</FONT><BR><B><FONT face=Arial size=2>Reiner Schlieker</FONT></B> <BR><FONT face=Arialsize=2>Test Equipment Designer</FONT> <BR><FONT face=Arial size=2>SiemensMilltronics Process Instruments Inc.</FONT> <BR><FONT face=Arial size=2>Phone:(705) 740-7553</FONT> <BR><FONT face=Arial size=2>Fax: (705) 740-7692</FONT> <BR><FONT face=Arial size=2>Email: reiner.schlieker@siemens.com</FONT> <BR><FONT face=Arialsize=2>Web: www.siemens-milltronics.com</FONT></P></SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPANclass=890345414-03092003></SPAN></FONT> </DIV><BLOCKQUOTE> <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Keith Williams [mailto:k.williams@umist.ac.uk]<BR><B>Sent:</B> Wednesday, September 03, 2003 10:03 AM<BR><B>To:</B> VEE vrf<BR><B>Subject:</B> [vrf] Panels<BR><BR></FONT></DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2>Hi,</FONT></SPAN></DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2></FONT></SPAN> </DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2>I have a VEE application which has a Main program with a panel and a UserObject with its own panel. What I would like to do is have the Main panel show when the application runs and then when the UserObject executes for its own panel to appear but in a completely separate window to the Main panel.</FONT></SPAN></DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2></FONT></SPAN> </DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2>At the moment if I enable the UserObject "show panel on execute" property then the panel displays in the Main panel window. If I clear the "show panel on execute" then the UserObject panel does not show at all when I run the application.</FONT></SPAN></DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2></FONT></SPAN> </DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2>Software is VEE Pro 6.1 on PC</FONT></SPAN></DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2></FONT></SPAN> </DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2>Any suggestions would be greatly appreciated. </FONT></SPAN></DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2></FONT></SPAN> </DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2>Regards <P><FONT face=Arial size=2>Keith Williams<BR>Senior Experimental Officer<BR>Microwave Group<BR>Dept. of Elec. Eng. & Electronics<BR>UMIST<BR>PO Box 88<BR>Manchester<BR>M60 1QD<BR></FONT></P></FONT></SPAN></DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2></FONT></SPAN> </DIV> <DIV><SPAN class=235295613-03092003><FONT face=Arial size=2></FONT></SPAN> </DIV>---<BR>You are currently subscribed to vrf as: reiner.schlieker@siemens.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
> Does anyone have any programming examples the show how to program these
> boards using VEE Pro 6.
> 777387-01 PCI-DIO-96
> 777641-02 PCI-485/2
> Thanks
Jerry
