Seppo Metsl <seppo.metsala@mil.fi> wrote:
> Thanks for the responses.
> I don't think it's merely about delay between commands. If I send just one
> command "lg" using direct I/O it does not work, but when done from UNIX it
> works.
check for terminators: cr or lf or cr/lf
odds are you seeing diff between the unix default
and the windows default
stan
> works.
stan
device is set to IEEE488 not 488.2. Also go to the plug and play driver tab
and uncheck the Perform ID query, and Perform Reset boxes. These are enabled
by default, and Vee could be sending the ID query and/or resetting the
device and it hangs because it does not understand the commands. To verify
this, bring up a GPIB monitor window and look at all the commands sent
across the bus before your program gets to your first Direct I/O statement.
Hope this helps,
Mike
Sent: Monday, January 20, 2003 1:40 AM
To: VEE vrf
Subject: [vrf] more about HP 5347A with XP and USB
works.
It might be something about faster computer and faster GPIB connection
(USB) compared to older HP 745 UX as Kathy said. But where to put delay if
I send just one command?
Seppo Metsl
You are currently subscribed to vrf as: michael.asbery@nrl.navy.mil
