Cagri and Alex-
We have used the 1553 cards from Condor Engineering for years. We had to write a simple dll to load parameters from vee to the structure needed for the vendor dll call. We only had to do four out of all the vendor functions to get what we needed to do.
Dave Andersen
Software Engineer
Communication Systems Division
General Dynamics Decision Systems
email: Dave.Andersen@gdds.com or
p26278@gd-decisionsystems.com
phone:(480) 441-8764
fax: (480) 441-8500
Sent: Wednesday, August 06, 2003 7:31 AM
To: VEE vrf
Subject: [vrf] Re: Vee with the 1553
Hi there,
I may have such kind of problems in the near future. Maybe we will use 1553
bus to communicate with some devices. From the e-mails I understand that the
only remedy to this problem is developing an interface program (between
vendor supplied dll's to VEE type dll's). For most of the cases, we apply
this solution. I mean a card or device without VEE drivers, etc.
Unfortunately I am not sure whether this is feasible. Just think of hundreds
of functions in a dll. I remember that four years ago I had utilized this
solution to a DAQ card without the VEE drivers. Another solution to this
problem is not even bothering with VEE and using the environment that the
drivers are supplied (C, Basic). Or a third case is forcing the
manufacturers to supply the drivers we need. Unfortunately today, we see no
cards/devices/etc with VEE drivers in the market. Is it very difficult to
develop these or the manufacturers ignore VEE users?
May anyone suggest better solutions?
Regards
Cagri
----- Original Message -----
To: "VEE vrf" <vrf@it.lists.it.agilent.com>
Sent: Friday, July 18, 2003 9:17 AM
> Yes.
> At Space Systems/Loral I used the Ballard Technology MIL-STD 1553 bus to
> talk to the Sequential Shunt Unit (SSU) used on the International Space
> Station. The SSU is a regulator that converts 82 constant-current solar
> arrays into a single constant-voltage output. The 1553 bus is used to
> command and control the SSU operation and receive status reports from it.
> Ballard supplied the PC interface board and a DLL. I wrote another DLL to
> convert from VEE data forms to Ballard's C data forms. Very
> straight-forward and simple.
> As for the ARINC-429, no personal experience. Looking at the Condor web
> site, it looks as if the interfacing their board is about the same. Plan
on
> writing a DLL to convert data from VEE to C forms and for possibly
> re-arranging bits.
> Robert Reavis
> Warm Springs Computer Works
> Fremont, California
> From: <Alex.Barrett@raytheon.co.uk>
> Sent: Thursday, July 17, 2003 7:45 AM
> Subject: [vrf] Vee with the 1553
> > Just a very brief question...
> > I'm wondering if anyone out there has ever used VEE to communicate to a
> > MIL-STD 1553 avionics bus interface card?
> > If anyone has ever done this, then PLEASE let me know, otherwise I shall
> be
> > forced to defect to the dark side and learn Labview - and we wouldn't
want
> > to do that would we?!
> > (Also if anyone's ever used VEE to talk on the ARINC-429 bus it would
be
> > useful too)
> > Many thanks,
> > Alex Barrett.
> > Test Development Dept.
> > Raytheon Systems Ltd, UK
Dave Andersen
Software Engineer
fax: (480) 441-8500
To: VEE vrf
Hi there,
Regards
Cagri
> Yes.
on
> re-arranging bits.
> Robert Reavis
> Fremont, California
> be
want
be
> > useful too)
> > Many thanks,
> > Alex Barrett.
If anyone has ever done this, then PLEASE let me know, otherwise I shall be
forced to defect to the dark side and learn Labview - and we wouldn't want
(Also if anyone's ever used VEE to talk on the ARINC-429 bus it would be
useful too)
Many thanks,
Alex Barrett.
