<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META content="MSHTML 5.50.4611.1300" name=GENERATOR></HEAD><BODY><DIV><SPAN class=947531515-05032003><FONT face="Times New Roman Special G1">Hello everyone,</FONT></SPAN></DIV><DIV><SPAN class=947531515-05032003> <FONT face="Times New Roman Special G1">I am a new member to the group and a new user to VEE Pro. I am hoping you all will be able to help me out and eventually I will be able to help some of you out.</FONT></SPAN></DIV><DIV><SPAN class=947531515-05032003><FONT face="Times New Roman Special G1"></FONT></SPAN> </DIV><DIV><SPAN class=947531515-05032003> <FONT face="Times New Roman Special G1">My question/problem has to do with the Instrument Manager. I understand how to configure my instruments. I have several user functions in my program and I noticed the Instrument Manager has embedded a configuration into the user function. I was thinking that I would use the VEE.io file for the configuration for all the user functions.</FONT></SPAN></DIV><DIV><SPAN class=947531515-05032003><FONT face="Times New Roman Special G1"></FONT></SPAN> </DIV><DIV><SPAN class=947531515-05032003> <FONT face="Times New Roman Special G1">If I make a change in the instrument configuration will I have to go back through all the user functions and change the instrument configuration in all the user functions?</FONT></SPAN></DIV><DIV><SPAN class=947531515-05032003><FONT face="Times New Roman Special G1"></FONT></SPAN> </DIV><DIV><SPAN class=947531515-05032003> <FONT face="Times New Roman Special G1">Is there a way to change the embedded configuration to the vee.io configuration? I can't find out how.</FONT></SPAN></DIV><DIV><SPAN class=947531515-05032003><FONT face="Times New Roman Special G1"></FONT></SPAN> </DIV><DIV><SPAN class=947531515-05032003> <FONT face="Times New Roman Special G1">All help will be appreciated.</FONT></SPAN></DIV><DIV><SPAN class=947531515-05032003><FONT face="Times New Roman Special G1"></FONT></SPAN> </DIV><DIV><SPAN class=947531515-05032003><FONT face="Times New Roman Special G1">Thank you,</FONT></SPAN></DIV><P><B><I><FONT size=5>J. Kevin Stokes</FONT></I></B> <BR><FONT face=Arial size=2>ITT/MEC</FONT> <BR><FONT face=Arial size=2>7670 Enon Drive</FONT> <BR><FONT face=Arial size=2>Roanoke, VA 24019</FONT> </P><P><FONT face=Arial size=2>Phone (540)777-5572</FONT> <BR><FONT face=Arial size=2>Fax (540)777-5601</FONT> <BR><FONT face=Arial size=2>kevin.stokes@itt.com</FONT> </P><DIV> </DIV></BODY></HTML><BR><P><FONT SIZE=2 FACE="Arial">************************************<BR><I>If this email is not intended for you, or you are not responsible for the delivery of this message to the addressee, please note that this message may contain ITT Privileged/Proprietary Information. In such a case, you may not copy or deliver this message to anyone. You should destroy this message and kindly notify the sender by reply email. Information contained in this message that does not relate to the business of ITT is neither endorsed by nor attributable to ITT.<BR>************************************ </I></FONT></P><BR>
