vrf Universal library for VEE
Question asked by tapio.ronkainen on Oct 1, 2003
Hello David & Vitale
Are you are aware of MC's "Universal Library for Vee" product? It is extremely easy tool to use for controlling MC's i/o cards. It add's an custom menu to Vee interface and the usage is dead simple, just select from menu and connect the input & output to normal Vee user function.
The Vee user functions that it add's can also be opened up, so you can pick up the low level programming underneath. If you need more speed & other mod's, you can modify the func's jusk like any other.
Check it out,
Saves a lot of time!
Tapio
> -----Original Message-----
> From: ext David J [mailto:testardj@inter.net.il]
> Sent: 02 October, 2003 11:45
> To: VEE vrf
> Subject: [vrf] Re: Universal library for VEE
> Vitale;
> On previous projects (2 years ago)  we used the DAS, DIO, and
> CTR cards.
> What is the question?
> David Jazcilevich (testardj@inter.net.il)
> ----- Original Message -----
> From: "Vitale, Jerry" <Jerry.Vitale@danahermotion.com>
> To: "VEE vrf" <vrf@it.lists.it.agilent.com>
> Sent: Wednesday, October 01, 2003 1:53 PM
> Subject: [vrf] Universal library for VEE
> Good morning,
> Is there someone in the group that is familiar with the
> universal library
> commands
> from Measurement Computing. If so, can you spare a few
> emails, I have a
> couple
> of questions to ask.
> Great group !!
> Thanks,
> Jerry
> Jerry Vitale
> Principle Design Engineer
> Danaher Motion
> Tel. (610) 692-2700 Ext. 250
> Fax.(610) 696-4294
> Email JVitale@apiharowe.com
> You are currently subscribed to vrf as: testardj@inter.net.il
> To send messages to this mailing list,  email
> "vrf@it.lists.it.agilent.com".
> You are currently subscribed to vrf as: tapio.ronkainen@nokia.com
