vrf Using Labview with Agilent 82350A
Question asked by VRFuser on Oct 14, 2003
Latest reply on Oct 14, 2003 by VRFuser
HI Jay,
Can you help me with this problem too....!!??
I'm tasked to do a automation program to automate waveform accquisition for
signal comparison for
a spectrum analyser (HP8539E from agilent) and a HPIB_PCI card (HP82350A
from agilent).
Presently, I am using Labview version 6.0 with Window 95 and have being
trying to configure the setup to automate
the accquisition of the waveform from the spectrum analyser.
My primary objective is
1) Accquire the signal from the spectrum analyser before device A is turn
on. Obtain the frequencies and the amplitudes for
those signals above a certain threshold and save the data as well as the
waveform.
2) Turn on device A and accquire the signal again. Similarly, the
frequencies and amplitudes for those peaks will be
captured and tabulated. The data and waveform will similarly be saved.
3) The pre and post signals will then be compared and the delta will be
tabulated for further manual checks.
However, I now faced problems even at the first stage... getting labview
to recognise and "talk" to the spectrum analyser.
Seems that Kiran is facing the same problem as me. Is there any way that
you guys are able to help??
Thanks a million in advance!!!
Regards!
Kianchuan
"Jay Nemeth-Johannes" <jay.johannes@completetest.com> 14/10/2003 10:31 PM
Please respond to "Jay Nemeth-Johannes"
              To:  "VEE vrf" <vrf@it.lists.it.agilent.com>
              cc:  (bcc: YEO Kian Chuan/Engr/ST Aero/ST Group)
              Subject: [vrf] Re: Using Labview with Agilent 82350A
Aw c'mon folks.
Yes, this is the VEE group, but over at the labview forum, nobody is going
to admit that the 82350 even exists.  There is no Agilent I/O forum, so
where is the poor guy supposed to go for answers?
Kiran, Agilent has just released a product called Test Automation Kit that
among other things addresses cross platform I/O.  We did extensive testing
of both the NI I/O card under Agilent I/O and the Agilent I/O cards under
LabVIEW. When properly configured, everything works on LabVIEW except MAX
(Measurement Automation Explorer, equivelent to Agilent VISA Assistant).  I
will send you a private message so that we don't bother this list with
details.
  Jay Nemeth-Johannes
  Complete Test
  720 SW 14th Street
  Loveland, Colorado 80528
  (970) 663-0006
  www.completetest.com
From: William J. Drago [mailto:wdrago@suffolk.lib.ny.us]
Sent: Tuesday, October 14, 2003 3:08 AM
To: VEE vrf
Try this:
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&safe=off&group=comp.lang
labview
-Bill
----- Original Message -----
Cc: "VEE vrf" <vrf@it.lists.it.agilent.com>
Sent: Tuesday, October 14, 2003 4:56 AM
> Hi Kiran,
> This is the Agilent (formally HP) VEE users group, and while there may
well
> be some LabView expertise here, it is probably not the best forum for you
> to get help with your issues......
> I am posting this back to the reflecter for reference: the LabView users
> forum resides on usenet and is - comp.lang.labview
> There are several web-to-news-to-mail services available if you have no
> access to NNTP
> Regards
> Paul F.
>                     "Kiran Anand"           To:  "VEE vrf"
>                     <kiran_anand@emitac.a   cc:
>                     e>                      Subject:  [vrf] Using Labview
with Agilent 82350A
>                               14/10/03
>           08:56
>           Please respond to "Kiran Anand"
>           Stationery name:-Untitled-
> Hello all,
> We request your assistance for the below.
> 1. We are facing a problem to use Agilent 82350A HPIB card with Labview
6.1
> in Windows 2000. The problem detail is attached in the mail. Kindly
advise
> how to fix the same. We verified the 82350A is installed OK & able to
> communicate with the instruments connected to the bus by using the VISA
> assistant in Agilent I/O.
> 2. If possible please provide a sample Labview program to verify the
> connectivity of the 82350A with any instrument connected.
> 3. Is it OK to install Labview & Agilent I/O Libraries in the D: drive as
> the C: drive cannot be accessed by students for security reasons?
> Many Thanks in advance.
> Best Regards,
> Kiran.
> (See attached file: Visa.jpg)---
> You are currently subscribed to vrf as: Paul.Fowler@raytheon.co.uk
> To send messages to this mailing list,  email
> "vrf@it.lists.it.agilent.com".
> You are currently subscribed to vrf as: wdrago@suffolk.lib.ny.us
You are currently subscribed to vrf as: jay.johannes@completetest.com
You are currently subscribed to vrf as: yeokianchuan@st.com.sg
[This e-mail is confidential and may also be privileged. If you are not the
intended recipient, please delete it and notify us immediately; you should
not copy or use it for any purpose, nor disclose its contents to any other
person. Thank you.]
