ditto
Jeff Davis
Lead Software Test Engineer
CDI Engineering Solutions Aerospace Technologies
Embedded Systems and Electronics
3137 E Elwood # 160
Phoenix, Arizona 85034
Phone: (602)431-4497 (x226)
Cell: (480)330-1431
Fax: (602)431-4435
> -----Original Message-----
> From: Mike Groves [mailto:mikegroves@pacbell.net]
> Sent: Thursday, October 02, 2003 11:29 PM
> To: VEE vrf
> Subject: [vrf] RE: Which OS
> Sorry, I don't consider ME a real OS.
> From: Shawn Fessenden [mailto:shawn@testech-ltd.com]
> Sent: Thursday, October 02, 2003 10:35 PM
> To: VEE vrf
> Once again, the problem:
> > CMD=((OS=="Windows_95" OR OS=="Windows_98") ? "COMMAND.COM"
> : "CMD.EXE")
> And for Windows ME this evaluates to? CMD.EXE? BZZZZZZT!
> Screw all this string stuff. Use the bits. There is
> DOS/Windows and there is
> Windows NT. That is all. Just look at bit 31 and you'll
> never, ever have any
> problem at all.
> -SHAWN-
> You are currently subscribed to vrf as: mikegroves@pacbell.net
> To send messages to this mailing list, email
> "vrf@it.lists.it.agilent.com".
> You are currently subscribed to vrf as: jeff.davis@cdi-es.com
> ______________________________________________________________
> __________
> This email has been scanned for all viruses by the MessageLabs Email
> Security System. For more information on a proactive email security
> service working around the clock, around the globe, visit
> http://www.messagelabs.com
> __________
________________________________________________________________________
Jeff Davis
3137 E Elwood # 160
Cell: (480)330-1431
Fax: (602)431-4435
> To: VEE vrf
> To: VEE vrf
> : "CMD.EXE")
> problem at all.
> -SHAWN-
> __________
> __________
is 'Windows 5.2' the version info for 'Windows Server 2003' ?
Do you have a link to a microsoft info on that topic?
If so, there would be no problem changing my code
best regards,
G. Nied
Georg Nied - Software-Development - Hansestr.7 - 51149 Cologne - Germany
Tel: +49 2203 9770915 - Fax: +49 2203 9770924 - eMail:info@gn-software.de
-------- Original Message --------
Subject: [vrf] Re: Which OS (02-Okt-2003 14:19)
To: vrf@it.lists.it.agilent.com
> Hi,
> your programm is O.K., but you ran in the same trap as the makers of VEE .
> There's now another Windows Version :
> 'Windows Server' with MajorVersion = 5 and MinorVersion = 2 !
> Detlef Kersten
> You are currently subscribed to vrf as: g.nied@gn-software.de
To: Analysetechnik@t-online.de (Analyse)
Detlef Kersten
Thank you very much for the help:)
Best regards
Marcus
From: g.nied@gn-software.de [mailto:g.nied@gn-software.de]
Sent: Thursday, October 02, 2003 10:27 AM
To: VEE vrf
Subject: [vrf] Re: Interface with MySql database
Hello Marcus,
here is what you need:
- Running MySQL Server
- MySQL ODBC Driver (V3.51 is actual)
- Microsoft ADO 2.5 Components (or above)
- create a database named 'test'
- create a file DSN named MyTestDB.DSN ( using
C:WINNTsystem32odbcad32.exe)
by selecting the MySQL ODBC Driver and a valid user account, wich must
be created earlier (test the connection afterwards !)
- the file MyTestDB.DSN it is stored under (C:ProgramsCommon
FilesODBCData Sources)
- add a table to the database by importing my demo script (contacts.sql)
- now you can run the attached vee example
If you are searching for a good administration tool for MySQL I can
recommend MySQLFront (www.mysqlfront.de) for free. Although development for
that tool has stopped, it is still downloadable:
http://mysqlfront.venturemedia.de/index.php?s=9503bf12672368f1fd43045383a767
13&act=ST&f=2&t=328
best regards,
G. Nied
version of the command processor to use. As long as MS keeps using CMD.EXE
for future versions, I'm satisfied with the following lines to do the job:
OS=WhichOS();
CMD=((OS=="Windows_95" OR OS=="Windows_98") ? "COMMAND.COM" : "CMD.EXE")
Mike Groves
Sent: Thursday, October 02, 2003 12:54 AM
To: VEE vrf
> I get Windoos_2000 when I run the function whichOS() . Why?!!
Welp, I'll tell ya - I humbly submit that the whichOS() function is
completely useless. It is guaranteed to break your software every time MS
decides to change the name of NT. The solution is to use GetVersion in
kernel32.dll (long __stdcall GetVersion(void);). The return value has bit 31
= 0 if you're running real Windows (NT) or bit 31 = 1 if you're running fake
Windows (3.1 + Win32s or 9x). The low-order byte reflects the specific major
version. The high-order byte of the low-order word specifies the minor
version. If the platform is NT, then the build number is in bits 30 to 23.
For the hex-challenged, that's:
dwVer = GetVersion();
bIsNT = NOT bit(dwVer, 31);
iMajor = bitAnd(dwVer, 0xff);
iMinor = bitAnd(dwVer, 0xff00);
iBuild = (bIsNT ? bitShift(bitAnd(dwVer, 0x7fff0000), -16) : -1);
Note that GetVersion has been superseded so at some point it will go away
(maybe). In that case, you'll have to use GetVersionEx which is a royal
pain, though it can probably be done a lot cleaner using a ramp to decode
the string. The attached GetVersionEx isn't efficient, but it works.
-SHAWN-
To: VEE vrf
Screw all this string stuff. Use the bits. There is DOS/Windows and there is
Windows NT. That is all. Just look at bit 31 and you'll never, ever have any
problem at all.
-SHAWN-
> with
> Windows Server MaV 5 MiV 1 PID 1
> WinXP MaV 5 MiV 1 PID 1
> Win2000 MaV 5 MiV 0 PID 1
> WinNT4 MaV 4 PID 1
> Win98 MaV 4 PID 0
> and so on ( this is only about ).
> In the happy time before XP most programmers including me only asked
> if ( MaV >= 5 )
> Version= " Win2000 ";
then wouldn't proper programming practice be to return
windows x.x
if the version can't be properly ID'd???
that is rather than returning a known incorrect value, wouldn't
something like this make more sense?
case
mav=4 and pid=0: version="98";
mav=4 and pid=1: version="NT4";
mav=5 and miv=0: version="2000";
mav=5 and miv=1: version="XP";
else: version=mav+"."+miv+"."+piv"
end case
that way the correct info is always returned in the future
as Windows evolves.
Stan
problem at all.
-SHAWN-
Mike, ME, was never intended as anything but a temporary solution by
those bit-brains in Microsoft's marketing department, while the real
geniuses there, the programmers, were busy building both versions of
XP. Anyone else, want to guess how frequently a system running ME,
would go for a crash? A lot more frequently then a box running 98, or
even both versions of XP.
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
> Sent: Friday, October 03, 2003 2:29 AM
> To: VEE vrf
> To: VEE vrf
> "CMD.EXE")
there is
have any
> problem at all.
> -SHAWN-
Sent: Thu 10/2/2003 7:59 PM
To: VEE vrf
Cc:
For me, it's REAL simple. The main purpose in my code is to find out which
OS=WhichOS();
Mike Groves
<mailto:shawn@testech-ltd.com> ]
To: VEE vrf
-SHAWN-
http://www.messagelabs.com <http://www.messagelabs.com>
http://www.geocities.com/rcwoolley/
Happy Friday!
Bill Ossmann
e-mail: bill.ossmann@philips.com
To: "VEE vrf" <vrf@it.lists.it.agilent.com>
cc: (bcc: Bill Ossmann/ANR/MS/PHILIPS)
"Gregg C Levine" Classification:
<hansolofalcon@worldnet.att.
net>
10/03/2003 10:21
Please respond to "Gregg C
Levine"
Hello (again) from Gregg C Levine
> To: VEE vrf
> To: VEE vrf
> "CMD.EXE")
there is
have any
> problem at all.
> -SHAWN-
You are currently subscribed to vrf as: bill.ossmann@philips.com
Well now that's true. It's definitely one of the fake ones
Hey Mike, I'm sorry about that rather rude comment. I only wanted to point
out how whichOS can trip you up, and it came out all wrong. I wasn't quite
myself last night. Please accept my apology.
-SHAWN-
or how about:
getEnv("COMSPEC")
that should do it.......
Paul F.
"Beliveau, Bruno" To: "VEE vrf" <vrf@it.lists.it.agilent.com>
<BrunoBeliveau@solect cc:
ron.com> Subject: [vrf] Re: Which OS
03/10/03
14:17
Please respond to "Beliveau,
Bruno"
Stationery name:-Untitled-
Why don't you just ask to the OS... Issue the dos command "Ver" thru
CMD.EXE. If CMD.EXE is not there, trap the error and try again with
COMMAND.COM. The dos command VER is pretty explicit on the OS version.
Unfortunately, you will need to redirect the reply to a file, read the file
and delete the file.
-----Message d'origine-----
De: Shawn Fessenden [mailto:shawn@testech-ltd.com]
Date: 3 octobre 2003 01:35
is
any
problem at all.
You are currently subscribed to vrf as: Paul.Fowler@raytheon.co.uk
