Hi Mike,
Thanks for the offer, but have solved my little problem.
The problem was due to our MIS department define a new workgroup
administrator file. (.mdw).
This caused a problem as it assigned security levels.
To access the database, the following code was used.
resultsTable (Declared) Recordset.
mdb (Declared) Database.
DBENG (Declared) DBEngine.
SET DBENG=createObject("DAO.DBEngine.35");
DBENG.SYSTEMDB="\\ntsrv1\common\dbfiles\system\example.mdw";
DBENG.systemdb;
DBENG.createworkspace("","admin","xxx",DBUSEJET);
Set mdb = DBENG.WORKSPACES(0).OpenDatabase(mdbFileSpec,False , False);
Set resultsTable = mdb.OpenRecordSet("qEnduranceTestData",dbOpenDynaset)
Maybe this will help somebody one day!
Regards
Gavin Candy.
Quality Engineer.
BHC Components Ltd
20-21 Cumberland Drive
Granby Industrial Estate
Weymouth
DT4 9TE
England
Tel: ++44 1305 830734
Fax: ++44 1305 760670
Email: gavin.candy@bhc.co.uk
website: http://www.bhc.co.uk
M Watts
<MikeJWatts@compu To: "INTERNET:gavin.candy@bhc.co.uk" <gavin.candy@bhc.co.uk>
serve.com> cc: "VEE vrf" <vrf@it.lists.it.agilent.com>
Subject: [vrf] MS Access problem
26/03/03 15:51
Hi Gavin,
Thanks for checking out my website - and for your comments.
I tried a few ideas based on your e-mail but, assuming there is a database
file at c:EnduranceTest.mdb, there is a table called TestDetails and that
you have exclusive rights to the database and table ( i.e. that you can
open them without having to give access to others ) I'm not sure what the
problem is. If you want to mail me an example ( suitably 'sanitised' such
that there is no sensitive data ) I'd be happy to have a quick look to see
if I can replicate the problem you see.
Mike Watts
Thankyou for all the replies concerning writing to Access &
compatibility
of Vee 6.0 with XP.
But I have another problem, using the example taken from
www.preciselyso.co.uk
I have successful created a database & can read/write to it. Great
tutorial.
But when I use the same code with a databases that we are using (have tried
several).
Declare db
Declare rst
Set db = createObject("DAO.DBEngine.35").OpenDatabase("c:
\EnduranceTest.mdb")
Set rst = db.OpenRecordSet("TestDetails")
I receive a error, informing me that I do not have permission to read the
table.
I have given full access rights to the database, but still get the same
problem!
Help! , has anybody else out there had a similar problem?
Thanks for help in advance
Regards
Gavin Candy.
Quality Engineer.
BHC Components Ltd
Weymouth
DT4 9TE
England
