Hi All
I finally figured out what went wrong in using variable thistest. Test
sequence was made in VEE 6 mode and it supports variable "thistest". The
Main program on the other hand was made using VEE 3 mode and thistest is
not allowed. After saving Main program in Vee 6 mode it worked OK.
When Main program is ran on Vee 3 mode and it is calling functions made in
Vee 6 mode, it "forces" execution mode to be 3 and therefore "variable not
found" error message was generated.
Seppo Metsala
ATE Engineer
Seppo Metsala
ATE Engineer
