> Folks - where are the attachments? Or is it that the VEE Program
> attachments are not sent out by the VRF Digest? Are they up on the
> server? How do I access the programs that you folks send out as
> examples?
> Thanks,
> DG
[deleted]
Deependra, we're looking at this problem and trying an experiment with a different personal setting in the vrf server (don't worry, this setting won't affect other vrf-ers). But it'll take at least a day, until I receive the next Digest, and I won't be back at work till Tuesday.
We'll get back to the vrf next weeks with results and hopefully recommendations on how to set yourself up for better attachment handling with Digests.
By the way, your email was over half a megabyte (it crashed my Outlook 2001 when I tried to Reply To All, no harm done).
To help keep the traffic down, especially for the many of our users still using modems to receive vrf, we recommend removing excess text in responses. In this case, removing everything in the digest text past say the first 100 or 200 lines would help, while still making the meaning clear. When I remove stuff, I like to put a little
[deleted]
mark to indicate that I did so, as I did near the beginning of this email.
Best Regards,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> examples?
> Thanks,
> DG
[deleted]
[deleted]
Best Regards,
Scott Bayes
970 679 3799 Tel
970 635 6867 Fax
examples?
DG
From: VEE vrf digest [mailto:vrf@it.lists.it.agilent.com]
Sent: Thursday, May 22, 2003 1:01 AM
To: vrf digest recipients
Subject: vrf digest: May 21, 2003
VRF Digest for Wednesday, May 21, 2003.
1. Re: Reading keyboard input
2. [VRF] arrays
3. AW: [VRF] arrays
4. RE: Reading keyboard input
5. RE: Get Instrument name from Instrument manager
6. Keyboard hook
7. developing with libraries
8. AW: developing with libraries
9. RE: developing with libraries
10. developing with libraries
11. Re: developing with libraries 1 of 2
12. Re: developing with libraries 2 of 2
13. Re: Strange Thread Flow Example.vee
14. Publishing in Web/Browser
Subject: Re: Reading keyboard input
Date: Wed, 21 May 2003 10:04:35 +0200
X-Message-Number: 1
This is a multi-part message in MIME format.
------=_NextPart_000_0022_01C31F80.6199CC10
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Paul:
Here is another example.
I adapted a program previously sent over the vrf.
This one reads the arrows "up" & ""down"
David J.
----- Original Message -----
To: "VEE vrf" <vrf@it.lists.it.agilent.com>
Sent: Wednesday, May 21, 2003 12:30 AM
Subject: [vrf] Reading keyboard input
> Hello,
> Does anyone know of a simple method for reading input from the
keyboard
> without using the text or message boxes supplied in VEE ?
> I'm already using the SendKeys method of VBScript, and wondered
whether
> there was a similar method for getting keystrokes rather than sending
them.
> Thanks in anticipation.
> Paul
> You are currently subscribed to vrf as: testardj@inter.net.il
Content-Type: application/octet-stream;
name="inkey$v1.vee"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="inkey$v1.vee"
(saveFormat "2.3")
(date "Wed 12/Feb/2003 14:24:56 ")
(veerev "5.01")
(platform "PC")
(execMode ole)
(filterNAN 0)
(workspaceStackingOrder M)
(SaveCF yes)
(Colors
(Property "Detail View" "Lightest Gray" bwGrayScale 10)
(Property "Panel View" "Light Blue Gray")
(Property "Workspace" "White")
(Property "Line Color" "Black" bwGrayScale 100)
(Property "Line Color (numeric)" "Dark Sky Blue" bwGrayScale 100)
(Property "Line Color (complex)" "Dark Sky Blue" bwGrayScale 100)
(Property "Line Color (string)" "Med Orange" bwGrayScale 100)
(Property "Line Color (sequence out)" "Black" bwGrayScale 100)
(Property "Line Color (highlight)" "Red" bwGrayScale 100)
(Property "Print ID Number BG Color" "Med Dark Gray" bwGrayScale 10)
(Property "Tool Tip" "Pale Yellow" bwGrayScale 0)
(Property "Tool Tip Text" "Black" bwGrayScale 100)
(Property "Object Title" "Blue Gray" bwGrayScale 30)
(Property "Object Title Text" "Black" bwGrayScale 100)
(Property "Object" "Light Blue Gray")
(Property "Object Text" "Black")
(Property "Object Shadow" "Darkest Gray")
(Property "Object Step Highlight" "Light Green")
(Property "Object Execute Highlight" "Yellow")
(Property "Object Trail Highlight" "Med Green")
(Property "Object Error Highlight" "Red")
(Property "Object Breakpoint Highlight" "Orange")
(Property "Object Discovery Highlight" "Blue")
(Property "Dialog Box Title Bar" "Dark Blue" bwGrayScale 30)
(Property "Dialog Box Title Bar Text" "White" bwGrayScale 100)
(Property "Dialog Box" "Gray")
(Property "Dialog Box Text" "Black")
(Property "Graph Background" "White" bwGrayScale 0)
(Property "Trace Pen 0" "Black" bwGrayScale 100)
(Property "Trace Pen 1" "White" bwGrayScale 100)
(Property "Trace Pen 2" "Red" bwGrayScale 100)
(Property "Trace Pen 3" "Green" bwGrayScale 100)
(Property "Trace Pen 4" "Yellow" bwGrayScale 100)
(Property "Trace Pen 5" "Blue" bwGrayScale 100)
(Property "Trace Pen 6" "Magenta" bwGrayScale 100)
(Property "Trace Pen 7" "Cyan" bwGrayScale 100)
(Property "Trace Pen 8" "Dark Yellow" bwGrayScale 100)
(Property "Trace Pen 9" "Dark Gray" bwGrayScale 100)
(Property "Edit Field" "White")
(Property "Edit Field Text" "Black")
(Property "Highlighted Edit Field" "Dark Blue")
(Property "Highlighted Edit Field Text" "White")
(Property "Menu" "Gray")
(Property "Menu Text" "Black")
(Property "Disabled Menu Text" "Dark Gray")
(Property "Highlighted Menu" "Dark Blue")
(Property "Highlighted Menu Text" "White"))
(Fonts
(Property "Menu Text" "Arial" 14)
(Property "Object Title Text" "Arial" 14)
(Property "Object Text" "Arial" 14)
(Property "Object Description Text" "Courier New" 14)
(Property "Terminal Text" "Arial" 12)
(Property "Notepad Text" "Courier New" 14)
(Property "Logging AlphaNumeric Text" "Courier New" 14)
(Property "AlphaNumeric Scalar Text" "Arial" 18)
(Property "AlphaNumeric Array Text" "Arial" 14)
(Property "Bus Monitor Text" "Courier New" 14)
(Property "Dialog Box Title Bar Text" "Arial" 14)
(Property "Dialog Box Text" "Arial" 12)
(Property "Printout Page Header Text" "Arial" 14)
(Property "Printout Object Title Text" "Arial" 14)
(Property "Printout Object Description Text" "Arial" 14)
(Property "Printout Object ID Number Text" "Arial" 12)
(Property "ToPrinter Printout Text" "Courier New" 14)
(Property "Tool Tip Text" "Arial" 12)
(Property "Graph Scale Label Text" "Arial" 10 bold))
(device 0 ROOTCONTEXT
(properties
(trigMode deg)
(nextID 94)
(popupTitleText "Untitled")
(popupMoveable 1)
(deleteGlobals 0))
(deviceList
(UserFunctions
(nextID 11)
(context 10
(properties
(name "User32")
(trigMode deg)
(nextID 49)
(popupTitleText "UserFunction")
(popupMoveable 1))
(deviceList
(device 2 IMPORT
(properties
(name "Import USER DLL")
(libType DLL)
(libName "C_user")
(fileName "user32.dll")
(defnFileName "header"))
(interface
(input 1
(type control)
(name "Definition File")
(tag "Definition File")
(requires
(datatype Text)
(shape "Scalar"))
(lock name constraints)
(optional yes)))
(implementation))
(device 3 TOFILE
(properties
(name "Write Header File")
(transactions 1 "WRITE TEXT a EOL"))
(interface
(input 1
(name "A")
(optional yes))
(input 2
(type control)
(name "File Name")
(requires
(datatype Text)
(shape "Scalar"))
(optional yes)))
(implementation
(attr iopath file write "header"
(readTerm "
(fs "
(eol "
(multiField fullSyntax)
(arrayFormat block))))
(device 13 START25)
(device 47 LITERALCONSTANT
(properties
(name "Header"))
(interface
(output 1
(name "Text")
(lock name constraints)))
(implementation
(value Text
(data "header"))
(initValue Text
(data ""))))
(device 48 LITERALCONSTANT
(properties
(name "Text"))
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "int __stdcall GetAsyncKeyState(int)"))
(initValue Text
(data ""))))
(configuration
(connect D1:0 D0:0)
(connect D3:1 D0:1)
(connect D3:0 D1:0)
(connect D4:1 D1:1)
(connect D3:1 D1:2)
(connect D2:0 D4:0)))
(contextCarrier
(active detail)
(detail
(extent 977 889)
(anchorPt 57 -82)
(configuration
(devCarrierFor 2
(active icon)
(icon
(extent 107 16))
(open
(extent 433 132))
(titleBg "Med Yellow Green")
(pinCenter 570 430))
(devCarrierFor 3
(active icon)
(icon
(extent 121 25))
(open
(extent 459 100))
(terminals on)
(titleBg "Cyan")
(pinCenter 570 360))
(devCarrierFor 13
(active open)
(icon)
(open
(extent 75 25))
(title off)
(pinCenter 310 210))
(devCarrierFor 47
(active open)
(icon
(extent 49 15))
(open
(extent 90 30))
(pinCenter 360 410))
(devCarrierFor 48
(active open)
(icon)
(open
(extent 262 35))
(pinCenter 290 350))
(connect D1:0 D0:0
(points 2 570 375 570 419))
(connect D3:1 D0:1
(points 4 407 410 450 410 450 430 514 430))
(connect D3:0 D1:0
(points 6 360 427 360 460 650 460 650 330 570 330 570 345))
(connect D4:1 D1:1
(points 2 423 350 507 350))
(connect D3:1 D1:2
(points 4 407 410 440 410 440 370 507 370))
(connect D2:0 D4:0
(points 4 310 225 310 250 290 250 290 312)))
(stackingOrder 2 1 0 4 3)))))
(device 23 CALL
(properties
(name "Call User32")
(callFunc "User32")
(parmMode rev30)))
(device 24 REPEATUNTILBREAK
(interface
(output 1
(name "Continuous")
(lock name constraints))))
(device 28 CALL
(properties
(name "Call GetAsyncKeyState")
(callFunc "GetAsyncKeyState")
(parmMode rev30))
(interface
(input 1
(name "int")
(requires
(datatype Int32)
(shape "Scalar"))
(optional yes))
(output 1
(name "vkey")
(optional yes))
(output 2
(type exception)
(name "Error")
(optional yes))))
(device 31 CONSTANT
(properties
(name "up"))
(interface
(output 1
(name "Int32")
(implementation
(value Int32
(data 38))
(initValue Int32
(data 0))))
(device 37 TOFILE
(properties
(name "Delete file")
(transactions 1 "EXECUTE DELETE"))
(interface
(input 1
(type control)
(name "File Name")
(requires
(datatype Text)
(shape "Scalar"))
(optional yes)))
(implementation
(readTerm "
(fs "
(eol "
(device 38 LITERALCONSTANT
(properties
(name "Header"))
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "header"))
(initValue Text
(data ""))))
(device 39 START25)
(device 43 CALL
(properties
(parmMode rev30))
(interface
(input 1
(name "int")
(requires
(datatype Int32)
(shape "Scalar"))
(optional yes))
(output 1
(name "vkey")
(optional yes))))
(device 44 CONSTANT
(properties
(name "down"))
(interface
(output 1
(name "Int32")
(implementation
(value Int32
(data 40))
(initValue Int32
(data 0))))
(device 47 CONSTANT
(properties
(name "Real"))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 0.5))
(initValue Real
(data 0))))
(device 49 CONSTANT
(properties
(name "Real"))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data -1))
(initValue Real
(data 0))))
(device 50 FORMULA
(properties
(expr 1 "dc =3D dc+a"))
(interface
(input 1
(name "A")
(optional yes))))
(device 51 JUNCTION
(properties
(name "JCT"))
(interface
(input 1
(name "A"))
(input 2
(name "B"))
(output 1
(name "Data"))))
(device 53 IFTHENELSE
(properties
(cases 1 "dc<0"))
(interface
(output 1
(name "Then")
(output 2
(name "Else")
(device 54 FORMULA
(properties
(expr 1 "dc =3D 0")))
(device 55 FROMGLOBAL
(properties
(name "Get dc")
(globalName "dc"))
(interface
(output 1
(name "Data")
(tag "Data")
(device 56 JUNCTION
(properties
(name "JCT"))
(interface
(input 1
(name "A"))
(input 2
(name "B"))
(output 1
(name "Data"))))
(device 58 TOGLOBAL
(properties
(name "Set dc")
(globalName "dc"))
(interface
(input 1
(name "Data")
(tag "Data"))))
(device 59 CONSTANT
(properties
(name "0"))
(interface
(output 1
(name "Int32")
(implementation
(value Int32
(data 0))
(initValue Int32
(data 0))))
(device 60 IFTHENELSE
(properties
(cases 1 "a!=3D0"))
(interface
(input 1
(name "A")
(optional yes))
(output 1
(name "Then")
(output 2
(name "Else")
(device 61 IFTHENELSE
(properties
(cases 1 "a!=3D0"))
(interface
(input 1
(name "A")
(optional yes))
(output 1
(name "Then")
(output 2
(name "Else")
(device 63 FROMGLOBAL
(properties
(name "Get dc")
(globalName "dc"))
(interface
(output 1
(name "Data")
(tag "Data")
(device 64 TEXTDISPLAY
(properties
(name "DC")
(clearAtPrerun 0)
(clearAtActivate 0))
(interface
(input 1
(name "Data"))))
(device 65 DELAY
(properties
(delay 0.2))
(interface
(output 1
(name "Done"))))
(device 67 LABEL
(properties
(name "To change DC press kybrd arrows up or down")
(labelValue "To change DC press kybrd arrows up or down"))
(implementation))
(device 73 TOGLOBAL
(properties
(name "Set dly")
(globalName "dly"))
(interface
(input 1
(name "Data")
(tag "Data"))))
(device 74 CONSTANT
(properties
(name "0.2"))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 0.2))
(initValue Real
(data 0))))
(device 90 EXITPROCESS
(properties
(code 0)))
(device 92 TOGGLE25
(properties
(name "Stop")
(initializeAtPrerun 1)
(initializeAtActivate 1))
(interface
(input 1
(type control)
(name "Reset")
(optional yes))
(output 1
(name "Toggle")
(implementation
(value Int32
(data 0))
(initValue Int32
(data 0))))
(device 93 IFTHENELSE
(properties
(cases 1 "a=3D=3D1"))
(interface
(input 1
(name "A")
(optional yes))
(output 1
(name "Then")
(output 2
(name "Else")
(configuration
(connect D2:2 D0:0)
(connect D6:0 D1:0)
(connect D1:1 D2:0)
(connect D3:1 D2:1)
(connect D29:1 D4:0)
(connect D5:1 D4:1)
(connect D2:0 D7:0)
(connect D8:1 D7:1)
(connect D19:1 D9:0)
(connect D20:1 D10:0)
(connect D12:1 D11:1)
(connect D9:1 D12:1)
(connect D10:1 D12:2)
(connect D11:0 D13:0)
(connect D13:1 D14:0)
(connect D16:1 D15:0)
(connect D14:0 D16:1)
(connect D21:1 D16:2)
(connect D18:1 D17:1)
(connect D0:0 D18:0)
(connect D2:1 D19:1)
(connect D7:1 D20:1)
(connect D13:2 D21:0)
(connect D15:1 D22:1)
(connect D22:0 D23:0)
(connect D26:1 D25:1)
(connect D18:0 D26:0)
(connect D4:0 D27:0)
(connect D7:0 D28:0)
(connect D28:1 D28:1)
(connect D28:1 D29:1))
(ShowOnExecPanel))
(contextCarrier
(wndOrigin 2 4)
(wndState res)
(active panel)
(panel
(extent 340 200)
(widget 6 detail
(relativeOrigin 100 100)
(bg "Med Green")
(fg "White")
(font "Arial" 16 bold)
(title off)
(borderStyle flat)
(extent 56 26))
(widget 28 detail
(relativeOrigin 100 130)
(bg "Warning Red")
(fg "White")
(title off)
(borderStyle flat)
(extent 56 26)
(scaled on)
(format button))
(widget 22 detail
(relativeOrigin 160 100)
(title on)
(borderStyle flat)
(extent 86 38))
(widget 24 detail
(relativeOrigin 10 160)
(title off)
(borderStyle none)
(extent 317 28)
(just l)))
(detail
(extent 809 661)
(anchorPt -595 -469)
(configuration
(devCarrierFor 23
(active icon)
(icon
(extent 80 16))
(open
(extent 196 53))
(terminals on)
(titleBg "Yellow")
(pinCenter 810 660))
(devCarrierFor 24
(active icon)
(icon
(extent 74 52)
(iconImage "loop.icn"))
(open)
(terminals on)
(pinCenter 600 580))
(devCarrierFor 28
(active icon)
(icon
(extent 160 25))
(open
(extent 196 62))
(terminals on)
(pinCenter 690 630))
(devCarrierFor 31
(active open)
(icon
(extent 20 0))
(open
(extent 84 30)
(showFormat int)
(formatter
(realFormat standard)
(realSigDigits 4)
(realRadixSpec 4)
(integerBase hexadecimal)))
(pinCenter 480 630))
(devCarrierFor 37
(active icon)
(icon
(extent 69 16))
(open
(extent 459 100))
(terminals on)
(titleBg "Cyan")
(pinCenter 950 860))
(devCarrierFor 38
(active icon)
(icon
(extent 49 14))
(open
(extent 90 30))
(pinCenter 870 860))
(devCarrierFor 39
(active open)
(icon)
(open
(extent 47 22))
(title off)
(pinCenter 600 510))
(devCarrierFor 43
(active icon)
(icon
(extent 160 16))
(open
(extent 196 62))
(terminals on)
(pinCenter 690 760))
(devCarrierFor 44
(active open)
(icon
(extent 37 0))
(open
(extent 84 30)
(showFormat int)
(formatter
(realSigDigits 4)
(realRadixSpec 4)
(pinCenter 480 760))
(devCarrierFor 47
(active icon)
(icon
(extent 33 16))
(open
(extent 69 30)
(showFormat real))
(pinCenter 970 640))
(devCarrierFor 49
(active icon)
(icon
(extent 33 16))
(open
(extent 69 30)
(showFormat real))
(pinCenter 920 770))
(devCarrierFor 50
(active icon)
(icon
(extent 57 16))
(open
(extent 110 42))
(terminals on)
(pinCenter 1110 650))
(devCarrierFor 51
(active icon)
(icon
(extent 29 25))
(open)
(terminals on)
(pinCenter 1050 650))
(devCarrierFor 53
(active icon)
(icon
(extent 82 25))
(open
(extent 63 53))
(terminals on)
(pinCenter 1110 690))
(devCarrierFor 54
(active icon)
(icon
(extent 57 16))
(open
(extent 76 32))
(terminals on)
(pinCenter 1230 690))
(devCarrierFor 55
(active icon)
(icon
(extent 46 16))
(open
(extent 81 53))
(terminals on)
(pinCenter 1320 740))
(devCarrierFor 56
(active icon)
(icon
(extent 29 25))
(open)
(terminals on)
(pinCenter 1270 720))
(devCarrierFor 58
(active icon)
(icon
(extent 44 16))
(open
(extent 81 53))
(terminals on)
(pinCenter 870 690))
(devCarrierFor 59
(active icon)
(icon
(extent 24 16))
(open
(extent 84 30)
(showFormat int))
(pinCenter 810 690))
(devCarrierFor 60
(active icon)
(icon
(extent 82 25))
(open
(extent 57 53))
(terminals on)
(pinCenter 900 620))
(devCarrierFor 61
(active icon)
(icon
(extent 82 25))
(open
(extent 57 53))
(terminals on)
(pinCenter 850 760))
(devCarrierFor 63
(active icon)
(icon
(extent 46 16))
(open
(extent 81 53))
(terminals on)
(pinCenter 1170 730))
(devCarrierFor 64
(active open)
(icon
(extent 24 0))
(open
(extent 131 28))
(pinCenter 1440 740))
(devCarrierFor 65
(active icon)
(icon
(extent 40 16))
(open
(extent 76 32))
(pinCenter 1440 820))
(devCarrierFor 67
(active open)
(icon
(extent 258 0))
(open
(extent 319 28)
(just l))
(title off)
(pinCenter 710 460))
(devCarrierFor 73
(active icon)
(icon
(extent 47 16))
(open
(extent 81 53))
(terminals on)
(pinCenter 870 720))
(devCarrierFor 74
(active icon)
(icon
(extent 24 16))
(open
(extent 69 30)
(showFormat real))
(pinCenter 810 720))
(devCarrierFor 90
(active icon)
(icon
(extent 68 52)
(iconImage "stop.icn"))
(open
(extent 69 32))
(pinCenter 950 920))
(devCarrierFor 92
(active open)
(icon
(extent 33 0))
(open
(extent 55 22)
(scaled on)
(format button))
(title off)
(bg "Warning Red")
(fg "White")
(titleBg "Warning Red")
(titleFg "White")
(pinCenter 690 820))
(devCarrierFor 93
(active icon)
(icon
(extent 82 25))
(open
(extent 60 53))
(terminals on)
(pinCenter 810 820))
(connect D2:2 D0:0
(points 3 772 640 810 640 810 649))
(connect D6:0 D1:0
(points 2 600 523 600 551))
(connect D1:1 D2:0
(points 3 639 580 690 580 690 615))
(connect D3:1 D2:1
(points 2 524 630 607 630))
(connect D29:1 D4:0
(points 3 853 810 950 810 950 849))
(connect D5:1 D4:1
(points 2 897 860 913 860))
(connect D2:0 D7:0
(points 2 690 645 690 749))
(connect D8:1 D7:1
(points 2 524 760 607 760))
(connect D19:1 D9:0
(points 3 943 610 970 610 970 629))
(points 3 893 750 920 750 920 759))
(points 2 1067 650 1079 650))
(connect D9:1 D12:1
(points 2 989 640 1033 640))
(points 4 939 770 1010 770 1010 660 1033 660))
(points 2 1110 660 1110 675))
(points 5 1153 680 1170 680 1170 660 1230 660 1230 679))
(points 3 1287 720 1320 720 1320 729))
(points 3 1230 700 1230 710 1253 710))
(points 2 1195 730 1253 730))
(points 2 824 690 845 690))
(connect D0:0 D18:0
(points 2 810 670 810 679))
(connect D2:1 D19:1
(points 2 772 620 856 620))
(connect D7:1 D20:1
(points 2 772 760 806 760))
(points 3 1153 700 1170 700 1170 719))
(points 2 1345 740 1372 740))
(points 2 1440 756 1440 809))
(points 2 824 720 844 720))
(points 2 810 700 810 709))
(connect D4:0 D27:0
(points 2 950 870 950 891))
(connect D7:0 D28:0
(points 2 690 770 690 806))
(points 6 720 820 740 820 740 790 640 790 640 820 660 820))
(points 2 720 820 766 820)))
(stackingOrder 8 0 12 11 13 21 16 15 7 22 19 9 29 27 5 4 28 2 18 17 26 =
25 3 1 6
24 23 14 20 10))
(numberFormats
(realSigDigits 4)
(realRadixSpec 4)
(integerBase decimal))))
------=_NextPart_000_0022_01C31F80.6199CC10--
