vrf VRF - 8720 - Turning off Aux channels
Question asked by warren.pickles on May 21, 2003
As far as I remember the command set for the 8720 is the same as for the
8753.  You select the channel then turn the auxiliary channel off, ie:
CHAN1;
AUXCOFF;
... turns off channel one's auxiliary channel, ie turn off channel 3.
Hope that helps.
From: RWalker@GeneralMicrowave.com [mailto:RWalker@GeneralMicrowave.com]
Sent: 22 May 2003 12:40
To: VEE vrf
Subject: [vrf] VRF - 8720 - Turning off Aux channels
VEE Users,
          Does anyone know how to turn off the Aux. Channels on an
8720 VNA via IEEE command?
Richard A. Walker
Herley - Farmingdale
425 Smith Street
Farmingdale, N.Y. 11735-1198
Direct Voice: (631) 630-2086
Main Voice: (631) 630-2000 X286
Fax: (631) 630-2066
mailto:RWalker@GeneralMicrowave.com <mailto:RWalker@GeneralMicrowave.com>
You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com
