I believe your error is that the direct IO object times out if the command
does not finish in under 5 seconds. Look at the advanced properties of the
33120 in your instrument manager and increase the timeout value to 30 sec or
whatever is needed to get the commands to complete. Alternately, you can
add a timeout control pin to the DirectIO object and define a timeout value
for that individual object.
Hope this helps,
Mike Asbery
From: Vikram Boyapati [mailto:boyapati@axiom-micro.com]
Sent: Thursday, September 11, 2003 10:12 PM
To: VEE vrf
Subject: [vrf] Agilent 33120A error
Folks,
Please look at attached VEE program and .txt file.
VEE Runtime Error as follows:
I/O error or timeout occured
Object: HP33120A
VEE error # 811
All I am trying to do is copy the floating point elements of the junk.txt
file to an array (in FROM FILE transaction) and then to the VOLATILE memory
of the 33120A (in the HP33120A object transaction). The error occurs at
transaction 1 of the HP33120A object.
I could do this with a smaller file (1156 elements in the array). No
errors.
Any insight would be appreciated.
Thanks.
Vikram Boyapati
Test Engineer
Axiom Microdevices, Inc.
2100 W Orangewood Avenue
#205
Orange, CA 92868
Phone: (714) 634 3827 ext 117
Fax: (714) 634 3760
Hope this helps,
Mike Asbery
To: VEE vrf
Folks,
Object: HP33120A
VEE error # 811
errors.
Thanks.
Vikram Boyapati
Test Engineer
#205
Orange, CA 92868
Fax: (714) 634 3760
Hope this helps,
Mike Asbery
To: VEE vrf
Folks,
Object: HP33120A
VEE error # 811
errors.
Thanks.
Vikram Boyapati
Test Engineer
#205
Orange, CA 92868
Fax: (714) 634 3760
