I keep getting an error 811 'I/O error or timeout occured SICL call made with
bad parameter - unable to set receive buffer size of 300 bytes"
This is on Com1 and the timout is set to 30s but the error occurs immediately
at run time. and yesterday mysteriouly failed every time , then started to
work correctly without error, and worked all day perfectly. Came to it today
after reboot of PC and get error everytime. Running at 19200 baud. If I
change buffer size it makes no difference. I got the Win2k I/O libs. from the
Agilent website.
Any suggestions???????? Com2 on the same PC works perfectly.
PC is a new Compaq Pentium 4 so is of reputable origin. I am running Vee
5.01
Ashley Derrick
Agilent website.
5.01
Ashley Derrick
I have triedan 811 error trap but it fails every time and works every time on Com2.
Incidentally, i have tried unistalling IO libsa nd then re installing but still no use.
Ashley
Will investigate the 'noisy'port suggestion
