Hello all,
I am trying to dump the screen of my oscillo and read the associated bitmap
file with the IO transaction box of VEE pro.
On my osciilo, I have set up the port and the device as "BMP" and "GPIB".
Then, from IO transaction box, I "WRITE" the command "SCREEN DUMP". The
oscillo is then sending something to the GPIB, but I don't know how to read
it. I tryied "READ" "BINARY" in "BYTE" format in a loop, but I cannot find
the end of the file. If I read not enough data, then the next command is
not understood by the oscillo (GPIB may be busy, OSCILLO may be in talk)
and if I read more data then necessary, there is an error during data
processing.
Did someone already dump the screen of his measurement tool with VEE pro?
Elisabeth Yoshida.
followed by some number of bytes of data. The header is:
typedef struct tagBITMAP {
LONG bmType;
LONG bmWidth;
LONG bmHeight;
LONG bmWidthBytes;
WORD bmPlanes;
WORD bmBitsPixel;
LPVOID bmBits;
The number of bytes of data is bmWidth * bmHeight * bmBitsPixel / 8. If it's
NOT a BMP bitmap then you'll have to find it's format in your instrument
manual. Unless some kind of compression is used it will always be a specific
number of bytes. If the scope is monochrome then most probably it's 1 bit
per pixel.
-SHAWN-
