vrf AW: SCREEN DUMP OF LECROY OSCILLO TO GPIB IN BMP FORMAT WIT H
Question asked by VRFuser on Jul 1, 2003
Thanks Hermann,
I 've just tried your solution. It is working.
Elisabeth.
|        |          hermann.ruckerbauer@in|
|        |          fineon.com            |
|        |          07/02/2003 09:50 AM   |
|        |          Please respond to     |
|        |          hermann.ruckerbauer   |
  |       To:     "VEE vrf" <vrf@it.lists.it.agilent.com>                                                     |
  |       cc:        |
  |       Subject:     [vrf] AW: SCREEN DUMP OF LECROY OSCILLO TO GPIB IN BMP FORMAT WIT     H VEE            |
I asked this question once in this group, and the best solution I found was
to read byte by byte until an error occurs.
This takes a long time, as there is generated a lot of overhead (every byte
is a single read commad), but it works
Hermann
Von: YoshidaE@ee.nec.de [mailto:YoshidaE@ee.nec.de]
Gesendet: Mittwoch, 2. Juli 2003 09:22
An: VEE vrf
Betreff: [vrf] SCREEN DUMP OF LECROY OSCILLO TO GPIB IN BMP FORMAT WITH VEE
Hello all,
I am trying to dump the screen of my oscillo and read the associated bitmap
file with the IO transaction box of VEE pro. On my osciilo, I have set up
the port and the device as "BMP" and "GPIB". Then, from IO transaction box,
I "WRITE" the command "SCREEN DUMP". The oscillo is then sending something
to the GPIB, but I don't know how to read it. I tryied "READ"  "BINARY" in
"BYTE" format in a loop, but I cannot find the end of the file. If I read
not enough data, then the next command is not understood by the oscillo
(GPIB may be busy, OSCILLO may be in talk) and if I read more data then
necessary, there is an error during data processing.
Did someone already dump the screen of his measurement tool with VEE pro?
Elisabeth Yoshida.
You are currently subscribed to vrf as: hermann.ruckerbauer@infineon.com To
subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
To send messages to this mailing list,  email
"vrf@it.lists.it.agilent.com".
You are currently subscribed to vrf as: YoshidaE@ee.nec.de
