Hi Paul,
Yes, it reproduced the same result in VEE 6.01.
But as you mentioned: Can this be usefull at all ????
Hermann
Von: Paul.Fowler@raytheon.co.uk [mailto:Paul.Fowler@raytheon.co.uk]
Gesendet: Mittwoch, 30. April 2003 11:25
An: VEE vrf
Cc: vrf@it.lists.it.agilent.com
Betreff: [vrf] Re: AW: RE: Strange Error with showPanel builtIn Function
Hi hermann
This is quite an interesting one, I'm not sure if it can be manipulated to
add any functionality..........??
See the attatched example, I'm using VEE5.01, so I can't guarantee it will
produce the same results on other versions......
Regards
Paul F.
(See attached file: showPanel_Example.vee)
hermann.ruckerbauer@in To: Paul.Fowler@raytheon.co.uk
fineon.com cc:
29/04/03 Subject: AW: [vrf] AW: RE:
17:14 Function
Hello Paul,
Thanks for trying to duplicate the effects ...
And you where right. The Programm really contained a UserFunction with this
name. And after removing it the problem was gone.
So thanks for your efforts!
Hermann
P.S. How did you even had the idea of the UserFunction with this name ?
Gesendet: Freitag, 25. April 2003 14:35
An: Ruckerbauer Hermann (MP TI PD DES5)
Betreff: Re: [vrf] AW: RE: Strange Error with showPanel builtIn Function
Just a suggestion, hermann...
Do you have a User Function called "showPanel" in your VEE program?
This is the only way I can duplicate the effects you describe....
Regards
Paul F
Hermann
An: VEE vrf
Hi hermann
Regards
Paul F.
fineon.com cc:
17:14 Function
Hello Paul,
Hermann
Regards
Paul F
