Hello Tom,
One of VEE's really strong points is that of dealing with data
and data types intelligently and so I would be surprised to see a problem
with VEE converting text "30" to a real to make the comparison.
I would check for strange characters in the text message e.g. you could use
the strLen function to determine that you really only have 2 characters in
your text number ( for debugging purposes ) or use the charToInt function
on both characters to ensure that you have ascii 51 and 48 ( and not, for
example, 51 and 79 ). If that is the problem, you should then trace where
the string is being corrupted.
Let us ( the vrf ) know how it goes: if you want to make an extract of your
program that shows the problem it may be easier to help you.
Mike Watts
_______________________________________________________________________
Michael J. Watts Consultant PO Box 92
Exeter
e-mail: MikeJWatts@CompuServe.Com Devon
tel: 07714 339 729 EX4 2YY
Mike Watts
Exeter
Currently I am sending email via SMTP with VEE. But, now I have a need to be able to send via SMTP in VB. I am having some issues getting it to work in VB (never used VB before). With some help I did get the email to send through Outlook, but the machines this will be running on will not have outlook installed. Would anyone have an example or help for me.
Thanks again,
Scott Anderson
Quality Engineer I
ADC Worldwide Operations
Tel : 952.403.8311
Fax : 952.403.8520
MS : 535
scott.anderson@adc.com
Learn about ADC - The Broadband Company at www.ADC.com
Mailing Address: P.O. Box 1101, Minneapolis, MN 55440-1101
Office Address: 1187 Park Place, Shakopee, MN 55379
