Jeremiah,
I did not see an answer to this one - I think the solution is easy - you
need to install the Agilent IO Libraries - this program will have come on a
CD which you will find in the Agilent VEE box.
Hope that helps,
Mike Watts
I am attempting to control an HP8591E Using direct IO in VEE. I am using
the serial connection. I am getting the error "Configuration Error: The
SICL I/O Library SICL32.dll could not be found Error #801". This occurs
when I attempt to send any command to my Spectrum Analyzer.
_______________________________________________________________________
Michael Watts, Consultant PO Box 92
on the web: www.PreciselySo.Co.UK Exeter,Devon
e-mail: MJWC@PreciselySo.Co.UK England
tel: +44 7714 339 729 EX4 2YY
Hope that helps,
Mike Watts
Jeremiah Fellows
IT Manager
Precision Devices, Inc.
Jeremiah_F@pdixtal.com
(608)831-4445 ext. 233
