Hi Ian,
If you use the XY trace display, using two data inputs, you can pass your
data in as either coordinates or mapped arrays, and they don't need to be
the same size at all. Therefore your data may contain 100 points and your
limit line can be a 10 point 'envelope' and it will plot ok.
Regards
David Watling
IGEORGE@KRONE.CO.
UK To: "VEE vrf" <vrf@it.lists.it.agilent.com>
cc:
06-Aug-2003 09:20 Subject: [vrf] X-Y Trace Control
AM
Please respond to
IGEORGE
Hi All VRF members.
Can anyone help me out? I need to display data and a Limit Line on an X-Y
Trace with a Fixed Frequency Scale for the X input. My measured data has
the same number of data points as the Frequency Scale input. So far so
good!
I also have a Limit line data which I can arrange to also be the same size
array as the data trace, however the limit line for my data should only be
visible over a portion of the frequency scale.
Does anyone know how I can 'hide' part of a trace or change the pen colour
of part of a trace (to 0 so it does not show)
I am using Vee 5.01
Any help would be very much appreciated.
Ian George
Technical Engineer
YOUR NETWORKS - OUR STRENGTH!
KRONE (UK) Technique Ltd
Runnings Road
Kingsditch Trading Estate
Cheltenham
Glos GL51 9NQ
UK
email: mailto:igeorge@krone.co.uk
Tel: +44 (0)1242 264503
Fax: +44 (0)1242 264488
You are currently subscribed to vrf as: Dave.Watling@Zarlink.Com
To send messages to this mailing list, email
"vrf@it.lists.it.agilent.com".
Can anyone help me out? I need to display data and a Limit Line on an X-Y Trace with a Fixed Frequency Scale for the X input. My measured data has the same number of data points as the Frequency Scale input. So far so good!
I also have a Limit line data which I can arrange to also be the same size array as the data trace, however the limit line for my data should only be visible over a portion of the frequency scale.
Does anyone know how I can 'hide' part of a trace or change the pen colour of part of a trace (to 0 so it does not show)
I am using Vee 5.01
Ian George
Technical Engineer
Runnings Road
Cheltenham
Glos GL51 9NQ
UK
