"Daly, Denis" <dalyd@tycoelectronics.com> wrote:
> Hi,
> I was wondering if you know how to open a network socket using HP
> VEE under Windows. The HP VEE manual only has instructions to do this
> under Unix and is called "To/From" Sockets where the port, host name, and
> timeout can be set.
> I was wondering if it works the same way under windows
Stan
> Hi,
> timeout can be set.
Stan
timeout can be set.
I was wondering if it works the same way under windows or if an automation
activeX control is required. I Thank you for any assistance you can provide.
Denis Daly
email: dalyd@tycoelectronics.com
