Yeah, I do the same thing. Whatever works!
Reiner
Sent: Tuesday, March 18, 2003 10:32 AM
To: VEE vrf
Subject: [vrf] RE: Vee ignoring breakpoints?
> I was just annoyed that it didn't work.
I know the feeling
I finally wound up with a global breakpoint var. Everywhere I wanted a
breakpoint I just used If gbBreak==True then execute a confirm button,
otherwise do nothing. Not pretty, but it works.
-SHAWN-
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
Reiner
To: VEE vrf
I know the feeling
-SHAWN-
Yes, please submit it as a defect on the Agilent Developers Network (ADN) at < www.agilent.com/find/adn >. You can register for the ADN Basic level for free. Once you're registered and logged in, click the Support link on the left of the page. That'll take you to a page containing the submission form.
If you can attach a small program that typically displays the problem, and/or describe any manual operations that cause the problem or increase the likelihood of it occurring, that will be helpful, since our first task is usually to reproduce the problem.
Sincerely,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> From: Young, Andrew [mailto:ayoung09@harris.com]
> Sent: Friday, March 14, 2003 11:31 AM
> To: VEE vrf
> Subject: [vrf] Vee ignoring breakpoints?
> I'm having problems with VEE ignoring breakpoints and was
> wondering if anyone on
> the VRF has any experience or insights. I'm running VEE Pro
> 6.0 on HP-UX 10.20
> and several times recently VEE has gotten into a mode where
> it ignores all
> breakpoints. A co-worker of mine also says that he's had
> intermittent problems,
> it may pause at one breakpoint, skip several and then pause
> at another. This
> has happened to me in two different programs, although they
> have had code pasted
> between them. If I save, exit VEE and reload the file it
> seems to work fine for
> a while but I can't figure out any trigger for this behavior.
> I tried looking
> on the website for information but had no luck.
> So does anyone have any idea what's going on here? Should I
> just submit this as
> a bug?
> Thanks in advance,
> Andy Young
> Harris Corporation
> You are currently subscribed to vrf as: scott_bayes@agilent.com
