Hello Reiner,
we have implemented the profibus-communication in our applications.
With an APPLICOM-PCIDPIO Card and over Active-X-Controls and an Applicom
OPC-Server you have full access to all Profibus-Clients (with GSD-Files).
The other way is the communication over a SIEMENS SLOT-SPS(WINAC Slot412...)
and the S7DATA-ControlReferenz. Here you have full access to all I/O's,
flags,
counters, DB's....
Horst Haas
heuer Automation GmbH
Heerweg 15A
D - 73770 Denkendorf
Telefon +49 (0) 7 11 / 93 18 40-13
Telefax +49 (0) 7 11 / 93 18 40-80
Email mailto:h.haas@heuer-automation.de
web http:\www.heuer-automation.de
flags,
counters, DB's....
Horst Haas
Heerweg 15A
I'm just starting a project that will need to test a product using Profibus
as the communication protocol. Has anyone implemented Profibus thru VEE?
Any recommendations for HW/SW? I've only just started reading up about
Profibus, but it seems that although dedicated HW is used to implement the
protocol, it can be done through SW alone (and using standard RS485 comms)
As the tester I'm implementing this on already has RS485 comm ability, I'm
wondering if this is a viable way to go.
Thanks in advance for any advice offered...
_____________________________________
Reiner Schlieker
Test Equipment Designer
Siemens Milltronics Process Instruments Inc.
Phone: (705) 740-7553
Fax: (705) 740-7692
Email: reiner.schlieker@siemens.com
Web: www.siemens-milltronics.com
