AW: vrf XY Trace Softcopy
Question asked by VRFuser on Nov 13, 2001
Hey Kathy,
what you also can do (and what I use): Install a (encapsulated) postscript
printer driver which is connected to a file output. Than you can use all
functions of the plot command with the right mouse click. One advantage of
this method is, that you get a vector graphic image which is scalable, not a
bitmap.
Martin Alles
ATMEL Germany GmbH
SiGe Frontends COM214
> You can use the SavePanelImage function and save as either a .bmp or .jpg.
> Kathy Kiessling
> Senior Test Engineer
> Endwave Corporation
> (408) 522-3160 ph
> (408) 820-2412 pg  <-- NEW
>  -----Original Message-----
> From:      Dykema Jim-P14701 [mailto:Jim.Dykema@gd-decisionsystems.com]
> Sent:     Tuesday, November 13, 2001 9:28 AM
> To:     'vrf@lvld.agilent.com'
> Subject:     RE: vrf XY Trace Softcopy
> Is there a simple way to generate a soft copy file of a XY trace object
> that
> is in a panel view that can be directly inserted into a Word document?
> I can generate a hard copy by right clicking on the XY Trace object,
> select
> plot and select a printer.  I would like to use the same approach but
> select
> a "graphics" driver that would create a file with a type that Word
> recognizes.
> Does any one know of such a driver?
> Jim Dykema
> General Dynamics
> Decisions Systems
> 8201 E. McDowell Rd.
> Scottsdale, AZ 85257
> Phone: (480) 675-2104
> FAX: (480) 441-3625
> Pager: (602) 204-0154
> This is the "vrf" maillist, managed by Majordomo.  To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".  Subscriptions and
