Does anyone have any examples of how to talk or listen
to a sound card useing MIDI commands with VEE?
Paul Chandler
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
Paul Chandler
Do you Yahoo!?
Does it work if you don't use a net directory but one on the local server?
Is the net directory located on a win2k or winxp machine? It may be the
windows authentication. Can you run the same command outside of Vee in a
DOS box?
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
"Kjeld Alexander"
<k.alexander@get2 To: "VEE vrf" <vrf@it.lists.it.agilent.com>
net.dk> cc:
Subject: [vrf] Re: win98 problem
09/25/2003 05:45
AM
Please respond to
"Kjeld Alexander"
Sorry
This one with prg
----- Original Message -----
To: VEE vrf
Sent: Thursday, September 25, 2003 9:29 AM
Subject: [vrf] win98 problem
Hi all,
I have 2 laptop, one running win98se vee6.01.The 2nd running XP home
vee6.01.
Running the attached program on xp home create folder(s) no problem.
No folder are createt on the win98se laptop.
Why is it a problem on the win98se laptop, with the same program. and
several other win98 PC.
Help on this matter needed.
Best Regards
Kjeld Alexander
You are currently subscribed to vrf as: k.alexander@get2net.dk
You are currently subscribed to vrf as: scubaman@us.ibm.com
#### mkdir.vee has been removed from this note on September 25, 2003 by
Richard Kleinhenz
Ugh! Yesterday I got to sit in front of a computer for seven hours feeding
it CDs. It hasn't been very intellectually taxing lately.
> BTW, I tried the various asVariant(asInt16()) castings plus every other
> permutation I could think of to no avail.
Bummer. This can only mean VEE doesn't do SAFEARRAY. This has to go on the
list of things to check out.
> write a simple dll to convert the data from VEE into the required
> type for the OCX.
That works wonderfully. Check out SafeArrayCreateVector,
SafeArrayPutElement, SafeArrayDestroy and VariantInit, all in the Automation
SDK.
-SHAWN-
P.S. I knew a Mike Watts about 25 years ago. Does OHS mean anything to you?
