You can add an error pin to your call then execute clear on the error
and try again.
Not a very clean solution certainly.
This type of error can be caused by a bad IB Cable or a loose
connection.
Regards, Gary
Gary Nelson
Ignis Optics Technical Staff
Phone: 408 869 8461
Cell: 408 710 1121
482 W San Carlos St
San Jose, Ca 95110
[mailto:resaleh@bomail.europe.nokia.com]
Sent: Monday, September 22, 2003 7:41 AM
To: VEE vrf
Subject: [vrf] Bluetooth Testing with ANRITSU MT8850A
I am a student trainee working with NOKIA and I am learning VEE program
for
test system development for bluetooth.
I am working on developing a software with ANRITSU MT 8850A for
bluetooth
testing of our devices. My version of VEE is 6.01
My purpose is to test the bluetoooth performance in different temp. For
this I need to wait at different temp and then again restart the program
automatically.
But I found that during the second (after passing the first one well and
waiting for some min.) temperature the program cannot connect the blue
tooth
device and generates a message saying connection timeout.
I had the idea that this is due to some error in the HP VEE software we
made.
So I built a small program (please see the attachment) which connects
the
ANRITSU and again disconnect and connect for continues time. But
unfortunately it was found some times I can make this connect-reconnect
process for 2 times, sometimes for 8 times or sometimes for 20 times and
at
the end always the message is "no connection made, timed out" and the
program fails to connect.
I tried to increase the "time out " time for reconnecting but the result
remained the same.
Is there any body here using the same ANRITSU for blue tooth testing? if
so
please can u see whether it performs the same . If possible can u please
give me some idea what I should do to solve this problem.
Regards
Reza Saleh
and try again.
connection.
Regards, Gary
Gary Nelson
Phone: 408 869 8461
Cell: 408 710 1121
482 W San Carlos St
San Jose, Ca 95110
To: VEE vrf
for
bluetooth
automatically.
tooth
made.
the
at
remained the same.
so
Regards
Reza Saleh
Thankyou Andrew good stuff here - I could have saved 30 on a book I just
ordered!
Dave
