vrf Damaged .VXE files
Question asked by ramarquardt on Dec 3, 2002
We had an experience with Windows NT where
.VXE files would be corrupted while in runtime VEE.
After replacing a suspected bad PC with no change in
results, we found a large momentary ground plane current
being generated by the system under rare circumstances.
We eliminated the ground current and haven't had a problem since.
....Rob
"Dwayne Rowland" <drowland@rfmd.com> on 12/04/2002 06:14:37 AM
Please respond to "Dwayne Rowland" <drowland@rfmd.com>
To:    "VEE vrf" <vrf@it.lists.it.agilent.com>
cc:
Subject:    [vrf] Re: WIN 2k& VEE5
I am  running Vee 5.01 with Windows 2000 with no problems.
Sent: Tuesday, December 03, 2002 6:18  PM
To: VEE vrf
The Agilent reply is rather interesting. I  am running VEE 5.01 on the
same laptop this email message is composed  on. The laptop is running
Microsoft Windows 2000 Professional. No  problem with running serial port
I/O, parallel port I/O with io_port.dll, and  Ethernet I/O.
Robert Reavis
Warm Springs Computer Works
Fremont, CA
----- Original Message -----
To: VEE vrf
Sent: Tuesday, December 03, 2002 2:22  PM
Subject: [vrf] WIN 2k& VEE5
Dear All,
Further to my previous question regarding upgrading I/O  libraries and
much help from Ralph, I received below from Agilent tech.  support. Is this
true?
Question
I need win 2k  I/O libraries for my registered copy of HPVee 5.01
I have found the  website with this but the download comes out at
300Mbytes. I
need the  archive file (6 MB) as AOL will not allow 300M download.
Please help
Rgds,
Ashley Derrick
Answer:
Madam,
Thank you for contacting Agilent Technologies. Your request for
support has been registered at technical support with the internal
reference ID shown in the subject field of this message.
With regard to your question, Vee version 5.01 doesn't  support Win 2000.
To run Vee on Win 2000, you need to upgrade your  software at least to the
version 6.0 which is now obsolete. The current  version is the version
6.1 (E2120A) which supports Windows  98/NT/2000/XP.
You are currently subscribed to vrf  as: robert@wscw.com
To subscribe send a blank email to  "join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to  "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing  list, email
"vrf@it.lists.it.agilent.com".
If you need help with the  mailing list send a message to
"owner-vrf@it.lists.it.agilent.com".  ---
You are currently subscribed to vrf as:  drowland@rfmd.com
You are currently subscribed to vrf as: ramarquardt@ra.rockwell.com
