Try going into VEE default prefs - printing tab and increase the print
magnification.
I sure wish VEE would scale the output automatically to the page size!
Reiner
From: Alex.Barrett@raytheon.co.uk [mailto:Alex.Barrett@raytheon.co.uk]
Sent: Wednesday, August 13, 2003 9:32 AM
To: VEE vrf
Subject: [vrf] A very small printing question...
Good afternoon all... (or morning to those of you just waking up over the
pond)
A very small question I really should know the answer to...
When printing an XY plot using the the 'print' control input, is there any
way making the print out larger?
The testers - the inconsiderate bunch that they are - seem upset that I'm
asking them to look at a Spectrum Analyser plot on a 3inch square printout
- They ask for sooo much.. - anyway, I thought I should ask to see if you
have any ideas....
afterthought..... our in house vee guru, overall genious and nice guy Paul
Fowler - that's a pint you owe me now Paul - thinks someone may have
answered this several months back...
Thanks all....
Alex.
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
magnification.
Reiner
To: VEE vrf
pond)
have any ideas....
Thanks all....
Alex.
asVariantNull() is not available in VEE 5.x, I believe.
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> From: Georg Nied [mailto:g.nied@gn-software.de]
> Sent: Wednesday, August 13, 2003 2:18 AM
> To: VEE vrf
> Subject: [vrf] RE: ActiveX Excel Worksheet.Move(After)
> Steve,
> you try to move an excel sheet with the function
> sheet.move([before],[after])
> the [] brackets indicate that the argument is optional but to
> leave out a
> leading argument is not possible from vee. You can use
> s.move(sheet(1)) to
> move sheet s before the first sheet but you cannot use
> s.move(,sheet(1)) to
> move s behind the first one. One solution would be to
> implement your need
> inside a VBA macro and call that macro from vee or to build a
> workaround.
> In case you just want to insert a specific amount of
> worksheets and rename
> them in a specific way you may act in two steps: first insert
> as many sheets
> as you need. Next loop over each sheet and rename it.
> You can use a 'for count' loop with a control input for the
> 'count'. Feet
> the formula result of '...worksheets.count()' (=N) to the
> control input.
> That loops from i=0 to N-1. Then feed the output to the formula
> '...worksheets(i+1).name='Datasheet "+(i+1)' to rename them.
> Hope that helps,
> best regards,
> G. Nied
> Georg Nied - Software-Development - Hansestr.7 - 51149
> Cologne - Germany
> Tel: +49 2203 9770915 - Fax: +49 2203 9770924 -
> eMail:info@gn-software.de
> You are currently subscribed to vrf as: scott_bayes@agilent.com
