http://www.preciselyso.co.uk/tool_tip.htm It will take a little
modification, but try the SEND KEYS tool found at the URL location attached.
Press the return button (or the space bar if you simply wish to press the
focused button) after the resman.exe Modal Dialog box gets focus.
OR -- Does the resman.exe allow a 'silent installation' ? Check to see if
there are any switches that you can throw from the win32 command line.
Check this page out - if it is an .msi installation, you are in luck:
http://www.netopia.com/en-us/support/howtodocs/netoctopus/msi.html
IF you get DESPERATE!! Check this out:
http://www.appdeploy.com/tools/appnstall/
I would use SEND KEYS before I did anything else.
Good Luck !!
Jeff Davis
Embedded Systems - CDI Technical Services
3137 E Elwood # 160
Phoenix, Arizona 85034
Phone: (602)431-4497 (x226)
Cell: (480)330-1431
Fax: (602)431-4435
http://www.cdicad.com
> -----Original Message-----
> From: Thomas.Mitchell@Autoliv.com [mailto:Thomas.Mitchell@Autoliv.com]
> Sent: Thursday, June 13, 2002 12:08 PM
> To: vrf@lvld.agilent.com
> Subject: vrf VEE & PCI-MXI-2
> I'm putting together a test system using a NI PCI-MXI-2 card
> and I have a
> question. Since I want it to be a turn key system, how can I
> get VEE to
> run resman.exe. I know how to start it, but the operator
> still needs to
> hit the return key.
> Any ideas to just execute this pgm?
> Thanks,
> Tom mitchell
> Autoliv
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".
> Subscriptions and
> _____________________________________________________________________
> This message has been checked for all known viruses by UUNET
> delivered
> through the MessageLabs Virus Control Centre. For further
> information visit
> http://www.uk.uu.net/products/security/virus/
This message has been checked for all known viruses by UUNET delivered
through the MessageLabs Virus Control Centre. For further information visit
Good Luck !!
Jeff Davis
3137 E Elwood # 160
Cell: (480)330-1431
Fax: (602)431-4435
> and I have a
> get VEE to
> still needs to
> hit the return key.
> Thanks,
> Tom mitchell
> Autoliv
> Subscriptions and
> delivered
> information visit
question. Since I want it to be a turn key system, how can I get VEE to
run resman.exe. I know how to start it, but the operator still needs to
hit the return key.
Tom mitchell
Autoliv
