Jan,
The problem you're seeing can be remedied by declaring your global variables first somewhere in the program, or running your program to the point where the global variables are initialized. Basically, if VEE "knows" the variable name you're trying to use in your IO transaction (i.e., it has been declared and/or initialized), it won't add the terminal on the input side of the box. I don't know of any other way to turn this feature off, though. Hope that helps.
Marc
Marc A. Engle
Product Engineer
Digital Cellular Product Line
RF Micro Devices, Inc.
7628 Thorndike Road
Mailstop : NC7628
Greensboro, NC 27409
Phone: 336-931-7445
Fax: 336-931-7371
E-mail: mengle@rfmd.com
From: Nielsen Jan [mailto:jan.nielsen@celsiusmetech.se]
Sent: Thursday, December 12, 2002 1:56 AM
To: VEE vrf
Subject: [vrf] Annoying Auto Input Terminal
Hi
When, in VEE 6.0 Pro, I add or edits a Write transaction in Direct I/O,
VEE automatically adds an input terminal with the same label as the variable I use in the transaction.
There is probably a good thought behind this, but it becomes very annoying when
I often use global variables and don't want any extra input terminals for these.
Does anybody know if there is a way to disable this function?
Jan Nielsen
Service Engineer RF, HF, ~
Direct +46 31 706 81 13
Mobile +46 70 551 47 28
Celsius Metech AB
Gamla Kungsbackavgen 15
431 61 Mlndal
SWEDEN
Tel +46 31 706 81 50
Fax +46 31 706 81 98
http://www.celsiusmetech.com
You are currently subscribed to vrf as: MEngle@RFMD.com
Marc
Marc A. Engle
Product Engineer
7628 Thorndike Road
Mailstop : NC7628
Phone: 336-931-7445
Fax: 336-931-7371
To: VEE vrf
Hi
Jan Nielsen
Celsius Metech AB
431 61 Mlndal
SWEDEN
Jan Nielsen
Celsius Metech AB
431 61 Mlndal
SWEDEN
