When I run my program I want it to be to the full size of the viewable area of the monitor. Problem I run into is when I place the position of the main panel every time I run the program after that it slowly creeps down. Any help is greatly appreciated. Thanks
Russell Fix
This message is for the designated recipient only and may
contain privileged, proprietary, or otherwise private information.
If you have received it in error, please notify the sender
immediately and delete the original. Any unauthorized use of
this email is prohibited.
Russell Fix
