Hello Harry,
Note that with RS-232 comms to the 34401 you need to send SYST:REM to set the instrument into remote. Also you need to set up handshaking to be DTR/DSR (and obviously set up stop bits, parity etc to be commensurate with the instrument).
Let me know if you need any more info
Andy
Andy Street
Technical Consultant
Agilent Technologies
Tel: +44-1189-275395
Mob: +44-7765-897003
Fax: +44-1189-276862
Sent: 11 June 2003 15:45
To: VEE vrf
Subject: [vrf] Serial Communications to 34401A DMM
Has anyone used RS232 communications to run a HP34401A?
I can send commands to the DMM but the DMM does not talk.
Any help would be greatly appreciated....Thanks!
Harry Kubiak
You are currently subscribed to vrf as: andy_street@agilent.com
Andy
Andy Street
To: VEE vrf
Harry Kubiak
Make sure that baud rate, parity, etc are set the same in the computer and
in the DMM.
Les Hammer
VP Engineering
Complete Test
720 SW 14th St.
Loveland, CO. 80537
Les.Hammer@CompleteTest.com
