vrf the new 6.2 evaluation download
Question asked by VRFuser on Aug 27, 2003
Hi vrf-ers,
The new 6.2 evaluation download has presented difficulties for a couple of you.
If you just want to run and evaluate VEE Pro, the evaluation installer process works well, but if you need to extract the Runtime, the Tutorials, or the pdf manuals, please keep reading.
By the way, the 6.2 manuals and tutorials are identical to those for 6.1, and the only difference to the 6.01 versions is the cover art work, not the contents. So you probably don't need the new 6.2 versions of these.
To extract and install the 6.2 Runtime from the evaluation download:
1. Download and double-click the self-extracting archive "download_veepro_6_2.exe"
2. After it finishes extracting the files, right-click on the "VEE6_2.exe" file that was unzipped from the download, and choose Open with WinZip. Don't double-click VEE6_2.exe, because if it runs as a self-extracting archive you will not be able to install VEERUN.
3. In WinZip, request extraction of all the files to a convenient location (I created a folder called "6.2 download" on my desktop).
4. After the files are extracted, double-click "cdsetup.exe". This will give you the buttons to choose between installing VEE Pro and VEE RUN.
The same process should work to get the Tutorials, though we haven't had a chance to try it yet. After you get into cdsetup.exe, you'll need to do a custom install, just as with 6.01 and 6.1
For the pdf manuals instead of step 4, go to the "books" folder, and retrieve the pdfs from there.
You can now throw away the downloaded file and excess unzipped files if you have everything you need.
Best Regards,
Nicole Dierksheide
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
