Hi Vincent,
I see that Majed Ali has already sent you my zip-file of GPS and Serial
programs.....
The GPS programs were developed using the Garmin GPS25 OEM receiver.
If you have any questions please feel free to contact me.
Stuart Roberts
Software Development Engineer
Channel Master
5 Commerce Park
Brunel Road
Theale
Berkshire
RG7 4AB
t: 01189 258107
f: 01189 303996
e: sroberts@cmltduk.com
From: Vincent Petrone [mailto:vpetrone@kathrein.com]
Sent: 06 October 2003 18:57
To: VEE vrf
Subject: [vrf] Garmin GPS V Personal Navigator
Has anyone had experience communicating with a Garmin GPS V Personal
Navigator using VEE via RS-232. If you have, I would appreciate a sample of
a program you have written and any other advice.
Vincent Petrone
Engineering Technician
Kathrein Inc. Scala Division
Medford, Oregon
You are currently subscribed to vrf as: SRoberts@cmltduk.com
_____________________________________________________________________
This message has been checked for all known viruses by Star Internet. http://www.star.net.uk/stats.asp or call Star Internet.
programs.....
Stuart Roberts
Channel Master
5 Commerce Park
Brunel Road
Theale
Berkshire
RG7 4AB
t: 01189 258107
f: 01189 303996
To: VEE vrf
Vincent Petrone
Medford, Oregon
<b><span style='font-weight:bold'>From:</span></b> Vincent Petrone[mailto:vpetrone@kathrein.com]
<b><span style='font-weight:bold'>Sent:</span></b> Monday, October 06, 20031:57 PM
<b><span style='font-weight:bold'>To:</span></b> VEE vrf
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] Garmin GPS VPersonal Navigator</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'><o:p> </o:p></span></font></p><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>Has anyone had experiencecommunicating with a Garmin GPS V Personal Navigator using VEE viaRS-232. If you have, I would appreciate a sample of a program you havewritten and any other advice. </span></font><o:p></o:p></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> <o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>Thanks,</span></font><o:p></o:p></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>Vincent Petrone</span></font><o:p></o:p></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> <o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>Engineering Technician</span></font><o:p></o:p></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>Kathrein Inc. Scala Division</span></font><o:p></o:p></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>Medford, Oregon </span></font><o:p></o:p></p></div><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'>---
You are currently subscribed to vrf as: kirk_reed@agilent.com
To subscribe send a blank email to"join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email"vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". <o:p></o:p></span></font></p></div>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></html>
I have a number of check boxes in my program (16 total) that I want to use to select
active channels (1 thru 16).
I'm looking for a slick way of looping thru all 16 to see if the output is a 1 or a zero
and then using that output to set channel numbers 1 thru 16.
I'm sure there is a simple solution - mine seems very cumbersome.
Thanks for your help
Steve
Is there a way to search an array of strings (something comparable to the comparator)
which will return the value contained in the desired element and the index?
Steve
