<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=Windows-1252"><TITLE>vrf: .vxe to .dll</TITLE><META content="MSHTML 5.50.4616.200" name=GENERATOR></HEAD><BODY><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2>Afraid not Stuart,</FONT></SPAN></DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2>when you import into VEE the extension does not matter, you can call your file .DOC and still import it into vee, but it does not make it a Word Document.</FONT></SPAN></DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2>Have a look on your C drive, find any DLL with windows explorer, right click and look at Quick View. Now do the same with your 'DLL' and check the difference.</FONT></SPAN></DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2>Gerard</FONT></SPAN></DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=990532110-23102001><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><BLOCKQUOTE dir=ltr style="MARGIN-RIGHT: 0px"> <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Stuart Roberts [mailto:Stuart.Roberts@siemens-datatrak.com]<BR><B>Sent:</B> Tuesday, 23 October 2001 11:15<BR><B>To:</B> Vee Reflector (E-mail)<BR><B>Subject:</B> vrf: .vxe to .dll<BR><BR></FONT></DIV> <P><FONT size=2>Hi all,</FONT> </P> <P><FONT size=2>Has anyone come across this before;</FONT> </P> <P><FONT size=2>I created a .vxe with a very simple user function that takes in a Int32 multiplies it by 10000 and returns an Int32. </FONT></P> <P><FONT size=2>This UF is called ten_thou and saved in ten_thou.vxe</FONT> </P> <P><FONT size=2>I then imported this UF into another .vee program all works fine.</FONT> </P> <P><FONT size=2>Then I had a brainwave, will this still work if I change the file extension from .vxe to .dll, this answer is yes !!</FONT> </P> <P><FONT size=2>So you can create .dll's in Vee by creating a .vxe containing the UF's and then changing the extension to .dll</FONT> </P> <P><FONT size=2>Can some one verify that this attached .dll will work with other windows programming languages.</FONT> </P><BR><BR> <P><FONT size=2>Stuart Roberts</FONT> </P> <P><FONT size=2>Validation Analyst</FONT> </P> <P><FONT size=2>Siemens Datatrak Location & Information Systems Ltd</FONT> <BR><FONT size=2>Wiltshire House,</FONT> <BR><FONT size=2>County Park,</FONT> <BR><FONT size=2>Swindon,</FONT> <BR><FONT size=2>WILTS.</FONT> <BR><FONT size=2>SN1 2NR</FONT> </P> <P><FONT size=2>t : +44(1793)508315</FONT> <BR><FONT size=2>f : +44(1793)500101</FONT> <BR><FONT size=2>e : stuart.roberts@siemens-datatrak.com |<A href="mailto:stuart.roberts@siemens-datatrak.com">mailto:stuart.roberts@siemens-datatrak.com</A>></FONT> <BR><FONT size=2>www : www.siemens-datatrak.com |<A target=_blank href="http://www.siemens-datatrak.com">http://www.siemens-datatrak.com</A>></FONT> </P> <P><FONT face=Arial color=#000000 size=2></FONT> </P></BLOCKQUOTE></BODY></HTML>
yes, I did see this error message with that component before. And I did not
find the reason for it. But it seems to have no side effects and it vanished
from time to time...
Georg Nied
Software-Development
Hansestr.7 - 51149 Cologne
Germany
Mail: info@gn-software.de
