Andres Rivas <arivas@giemdp.com.ar> wrote:
> Hi
> Im pretty a rookie in VEE, Im trying to run one of the examples and VEE
> prompts a message:
> cant find STATE DRIVER
> hpe1413.cid
> I couldnt find it in Agilent website neither.
check
http://ftp.agilent.com/pub/mpusup/veedrivers/index.html
You'll find the hpe1413.id (source code) and .ih (help file) files
Then look in your VEE install directoty and find the idc.exe
executable. This is the compiler you need to compile the hpe1413.id
source code into the hpe1413.cid "state driver" that you are looking for.
Simple command line usage idc <source code>
regards
Stan
> Hi
> prompts a message:
> hpe1413.cid
check
regards
Stan
prompts a message:
hpe1413.cid
Anyone has a suggestion?
Thank you in advance for your cooperation.
Andres Rivas
GIE
Mar del Plata
Argentina
