hello,
i have a problem with the logging data field names in the sequencer. is
there a possibility to rename
the fieldname of the linevalue and the record fieldnames after the
sequencer runs.
example:
linename test1 in the sequencer
linename test2 in the sequencer
linename test3 in the sequencer
linename test4 in the sequencer
linename test5 in the sequencer
after sequencer rename in test2 in test1_1
thanks for comments.
Viele Gre
Best regards
i. A.
Stefan Feuerecker Dipl.Ing. (FH)
Entwicklung Testsysteme
Testing Device Construction
_______________________________________________________
bebro electronic GmbH
Max-Planck-Str. 6-8 - D 72636 Frickenhausen
Tel.: +49 (0) 70 22 - 40 03 - 144 - Fax.: +49 (0) 70 22 - 4 27 72
E-Mail: s.feuerecker@bebro.de - Internet: http://www.bebro.de
sequencer runs.
example:
Viele Gre
Best regards
i. A.
if you just want the last element in an array why not use
Ary[totSize(Ary)-1] ?
Mike Watts
