Hello everybody,
I'd like to get out s2p,citi and setup file from 8753 network analyzer .
I can get trace data, but not file.
Is it possible to send control signal from VEE to 8753, to save data to external drive and use VEE as external drive, so saved data goes from analyzer to PC?
(Transfer file from 8753 to PC)
I'm also looking any example how to use pass control with 8753
Tomasz Niemira
Tomasz Niemira
Longer answer, the 8753 does allow writing to an external GP-IB disk, so if you could emulate an external disk over GP-IB, you might be able to get it to write to you.
However, this seems very hard way to do it. It is much easier to just use the output commands to get the data out.
If you want to get the instrument state out, you can output the learn string. If you want error correction as well, you output those arrays. And if you want the data, you output the data arrays. If you can't find it in previous posts, I can post a VEE program with the data reads.
Joel
Sent: Friday, October 17, 2003 6:55 AM
To: VEE vrf
Subject: [vrf] Pass control with 8753
Hello everybody,
Tomasz Niemira
You are currently subscribed to vrf as: joel_dunsmore@agilent.com
