Majed,
All you need for a simple filter is to send the data through the fft()
function, multiply by the filter transfer function, and then send the result
through the ifft() function. The filter function can be anything you want,
even if it is not strictly "realizable", so you could use just a simple
brick wall that is 1 up to 300 Hz and 0 beyond 300 Hz.
Bill Ossmann
bill_ossmann@hsgmed.com
Philips Ultrasound
>-----Original Message-----
>From: majed.ali@secrc.abb.se [mailto:majed.ali@secrc.abb.se]
>Sent: Friday, February 08, 2002 2:29 AM
>To: vrf@lvld.agilent.com
>Subject: vrf Lowpass filter
>Hi
>I have a measured signal and I want to send it thruogh a
>Lowpass filter to reject all the frequencies higher than 300
>Hz using the
>functions in VEE pro 6.01 or Matlabscript. Dose anyone build a
>lowpass filter.
>Any feedback would be appreciated.
>Best regards
>Majed Ali
>ABB Corporate Research
>This is the "vrf" maillist, managed by Majordomo. To send messages to
>this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
>unsubscriptions are done through the address
>"vrf-request@lvld.agilent.com".
>If you need details, just send a message containing the text "help"
>to "vrf-request@lvld.agilent.com".
Bill Ossmann
Philips Ultrasound
>Hi
>Hz using the
>lowpass filter.
>Best regards
>Majed Ali
I have a measured signal and I want to send it thruogh a Lowpass filter to reject all the frequencies higher than 300 Hz using the
functions in VEE pro 6.01 or Matlabscript. Dose anyone build a lowpass filter.
Best regards
Majed Ali
