Christian,
Following up on Jerry's suggestion, I use MSComm32 for all my serial
port needs (although I intend to switch to JS Payne's IO.ocx in the
future) and I have some sample code I could provide if you're
interested. Send a message.
Barrie
Barrie
My problem is that I have to release the serial port after use without
shutting VEE down.
As it is now, I have to shut down VEE in order to use the same COM port from
another program.
Thanks
Christian Hansen
######## Christian Hansen
#|'##### SW System Engineer
#| '### Wireless Application Center
#| ># Niels Jernes Vej 10
#| ,### DK9220 Aalborg Oest, Denmark
#|,##### Phone: +45 9635 4591
######## Fax: +45 9635 4481
