vrf AC Measurements using HP34970A
Question asked by VRFuser on Apr 29, 2002
Thanks to everybody who replied.
I believe I figured out the problem.
The device I am measuring, also passes DC voltage.
I am taking a DC voltage measurement & then a AC measurement straight
afterwards.
When manually checking the display, if you take a DC measurement using the
same
channel , then change the display to read the AC voltage, the reading first
appears
as 1.38vac & then changes to 0.899vac.
If I force the HP34970A to read the AC reading twice in VeePro. The first
reading
is 1.38vac & then the second value is correct. After investigating this, it
appears it only
the first reading that is wrong!
Anyway thanks again to everybody who made suggestions.
Gavin Candy.
Quality Engineer.
BHC Aerovox Ltd
20-21 Cumberland Drive
Granby Industrial Estate
Weymouth
DT4 9TE
England
Tel:           ++44  1305 782871
Fax:          ++44  1305 760670
Email:        gavin.candy@bhc.co.uk
website:    http://www.bhc.co.uk
