Greetings,
I'm having a little difficulty passing a char *value from VEE to a DLL I
wrote in C.
Conceptually I would imagine that this is little different than the example
named 'manual49.vee' in which an array of type double is used.
Recall the function call from manual49.c:
DLLEXPORT long myFunc(long arraySize, double *array)
My function is very similar:
DLLEXPORT int bfEncrypt(char *Data, const int DataLength, char *Key, int
KeySize)
>From VEE I pass some simple text to *Data (i.e. "Phil") and no problem.
However, VEE complains about the size 16 text array that I attemt to pass to
*Key. The exact response from VEE is:
"Value must be a scalar"
But recall from the example manual49.c an array of type double was passed
with no issue. What am I missing?
-Phil
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp. is the "vrf" maillist, managed by Majordomo. To send messages to
wrote in C.
KeySize)
-Phil
